Current offset is +15. I wanna go lower. What spacers?
Old Mar 20, 2010 | 01:16 AM
TIAN's Avatar
Hold The Line
Like title states. I'm thinking I should be fine with a 10mm spacer all around bringing me to +5. Gonna need a fender roll correct? Any help with specific reliable brands?
If you have any spacers for sale PM me.
Old Mar 20, 2010 | 01:17 AM
deeznutts23's Avatar
whats your wheel specs?
Old Mar 20, 2010 | 01:20 AM
TIAN's Avatar
Hold The Line
19x9.5 / Rear - 19x10.5 +15 all around
Old Mar 20, 2010 | 01:22 AM
340tog35's Avatar
Old Mar 20, 2010 | 01:25 AM
you are def going to need a fender roll. i dont know how you arent rubbing now with the sizes you are running. im running the same widths on my meisters except im at +7 i believe. ask some of your local guys if they can give you a hand rolling your fenders
Old Mar 20, 2010 | 01:28 AM
TIAN's Avatar
Hold The Line
Danny could. I have enough - camber to keep em from rubbing but I have a good amount of clearance either way. I think I should be flush at +5 eh?
Old Mar 20, 2010 | 01:53 AM
yeah flush for sure. your car must be as high as a 4x4 if you aren't rubbing right now. i would roll the fenders before you put the spacers on tho. lemme get you a pic of how mine sits
Old Mar 20, 2010 | 01:58 AM
Old Mar 20, 2010 | 01:59 AM
I had to raise my car up b/c I live in the woods now. It used to be WAYYY lower
Old Mar 20, 2010 | 02:00 AM
TIAN's Avatar
Hold The Line
Im actually pretty low. One of the lowest Gs in my area. Running Tanabes DF210s on sport suspension.
Old Mar 21, 2010 | 02:57 AM
4DGS's Avatar
Look at it like this;
Every inch, is a negative degree of camber.
Every negative degree of camber is about 10mm
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
Daniel k.
Nov 3, 2015 09:52 AM
reavensf
Sep 17, 2015 11:30 PM
paolojericho11
Sep 11, 2015 07:08 AM
