Got Stillen Sway bars
Old Sep 19, 2004 | 01:18 AM
malx's Avatar
Okay so I got my sway bars (on their way) and some other goodies as well. I also ordered two new rear back tires. I want to know what you guys think the best setup is? I know they are adjustable. I'm going to have to make up for some understeer in the front but I don't want my back to swing out too much. I also got Tein H-Tech springs. What settings do you guys think should I use on the sway bars? Ride quality does not concern me at all. I'm more interested in performance.
Thanks - Joey Avino
Old Sep 19, 2004 | 09:45 PM
malx's Avatar
Re: Got Stillen Sway bars
bumpz0r
Thanks - Joey Avino
Old Sep 20, 2004 | 08:10 AM
malx's Avatar
Okay so I decided to go Medium in the front and Stiff in the rear.
Thanks - Joey Avino
Old Sep 20, 2004 | 03:09 PM
hector2112's Avatar
how do you like that set up. I am ordering them now also. I am having a lot of issues with rubbing so i am redoing the whole suspension.
Old Sep 20, 2004 | 03:46 PM
cato's Avatar
SouthernComfort Moderator
I also got the Stillen sways. I went Stiff/Stiff as I don't know
how to determine what is the best. So just how do you
determine the optimum settings?
03 5AT Sedan, sunroof, splashguards, HKS muffler,
14 wire Grounding kit, Z Duct, Stillen HF/AB
Underbody rear diffusers, Drilled alum pedals,
Stillen sway bars H/H
Old Sep 20, 2004 | 06:05 PM
malx's Avatar
No idea... it just seems like Medium / Stiff is the best setup for me judging on how my new rear tires will grip alot better than the front with the understeer issues I want a softer front. Since the stiffer setting in the rear will do a better job (theoridically) of keeping my tires flat on the road I will get a more even wear and better traction on first and second gear (Since the rear tires don't turn).
I think... hehe [img]/w3timages/icons/smile.gif[/img]
Thanks - Joey Avino
Old Sep 20, 2004 | 07:06 PM
RacerX's Avatar
With the stock springs and tires, I tried Medium front, Stiff Rear, and found the rear wanted to step out so much, the VDC was working way too often. Medium/Medium worked great. Part of the beauty of adjustable bars is that they can compensate for differences in spings and wheel/tire combos. Several people have posted that the Tein springs shift the handling balance to understeer, so your conclusion makes perfect sense.
04 G35s 6MT BS Aero Kit/Nav/Prem
Warning: Objects in Mirror Are Losing!
Old Sep 20, 2004 | 08:33 PM
malx's Avatar
Oh wow... thank you... I like you.
Can I keep you?
Thanks - Joey Avino
Old Sep 23, 2004 | 11:12 PM
GRider35c's Avatar
yeah, med / med...
theyre gggggggrrrrrrrreeeeeeeaaaaaaattttttt!
04 / Black on Black / aero / splash / prem / perf / cc / 22%tint
z-tube / k&n drop-in / Stillen anti-sway bars / side-blinker mod
Eclipse AudioVideoNavigation 2454 / 10W6 sealed + 250/1 (temporary)
Old Sep 24, 2004 | 07:54 AM
Q45tech's Avatar
Try the softest front setting and medium rear.
Most cars come with an overagrressive front bar [to insure the understeer process] that tends to wash out front tires earlier than necessary.
Remember sway bars work by reducing tire traction at the end where they are stiffest............since rear has more than front [without power applied] .
Old Sep 24, 2004 | 10:36 AM
malx's Avatar
That's not correct Q45. The rear tires on our coupe usually go first. I confirmed this with Infiniti service.
Thanks - Joey Avino
Old Sep 24, 2004 | 11:09 AM
Gsedan35's Avatar
I support what Qtech is saying here, but from a position of, try mild settings first and work up to find the magic mix that is bliss. You'll know you've done it right when you can come back and say, "oh man this car is such a killer blast to drive at the limit, it's neutral, back end is perfectly behaved",......or something like that. (grin)
Keep in mind that you need to be open to the fact that you may not be the greatest assesor as to what is really going on and why. Make a fresh start here, from scratch. I would start off with the front holes set at 2, rear 3 and test, make changes as needed. In any event, if the bar specs are true, I would never consider running the front bar at full stiff or 70% stiffer then oem.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Sep 24, 2004 | 11:12 AM
Gsedan35's Avatar
<hr></blockquote>
Either you were naughty and gave it gas at the adheasion limit or did and don't know that you did or your rear tires are getting close to wearing out, or your alignment settings are poor.
Edmund Burke
G35 6mt
Old Sep 24, 2004 | 11:20 AM
malx's Avatar
When I drive I slam on the gas midway through the turn to let the back swing out on purpose. That's why I want the rear stiffer... ya dig?
Thanks - Joey Avino
Old Sep 24, 2004 | 11:23 AM
malx's Avatar
Beisde I have not understeered on my coupe yet except for one time in the snow but that's a given. I'm stickling with my med/hard setting first. I want to keep the rear tires as flat as they could be.
Thanks - Joey Avino
