225 40 19 front and 255 40 19 rear ?
Old Apr 25, 2010 | 10:30 PM
dealaddict1231's Avatar
Can someone please let me know if this would work?
225 40 19 FRONT AND 255 40 19 REAR
Would the performance change at all, and would this damage the car?
Old Apr 26, 2010 | 09:18 PM
Anyone???I am from Canada
Old Apr 26, 2010 | 09:21 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
yes it will work and wont be a noticeable change if you're sticking with the same tire. The only way you'll notice a change is if the new tires are better or worse than the current tires.
-GP-
Old Jun 1, 2010 | 12:30 PM
mpradana's Avatar
yea it will work. ru on oem 19's rays??
i have the same setup, 225/40 front and 255/40 rear.
Old Jun 1, 2010 | 02:08 PM
lag35driver's Avatar
BMW
Yes. It will work.
Old Jun 2, 2010 | 03:42 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Have seen others with that size as well.
Old Jun 2, 2010 | 03:43 PM
HenryLee's Avatar
works fine
Old Jun 2, 2010 | 03:49 PM
Jeff92se's Avatar
Red Card Crew
Touch taller than oem but probably within acceptable limits.
If you are running coupe wheels on a sedan, I'd recommend 255-35-19s though
Old Jun 2, 2010 | 07:45 PM
lakerschamp2000's Avatar
this would be way to small size for both coupe and sedan
Old Jun 2, 2010 | 07:51 PM
Ray76's Avatar
No it's not, that's what Im running.
Jeff92se's Avatar
Red Card Crew
Actually no it is not.
Sedan
245-40-19 is a touch bigger than the 215-55-17
255-35-19 is a touch smaller than the 215-55-17.
Obviously a 255-40-19 is a touch bigger than the oem 245-40-19.
255-35 isn't revelant to the coupe portion of this discussion
I've done all the leg work already.
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
215/55-17 4.7in 13.2in 26.3in 82.7in 767 0.0%
245/40-19 3.9in 13.4in 26.7in 83.9in 755 1.5%
255/35-19 3.5in 13.0in 26.0in 81.8in 775 -1.1%
255/40-19 4.0in 13.5in 27.0in 84.9in 746 2.7%
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
