Negative Camber?
Old Apr 30, 2010 | 12:39 PM
saoLin413's Avatar
Negative Camber?
Question, running 2.8 degrees of negative camber all around, my caster and toe are in factory spec. With brand new all season tires and a tread wear rating of 340 AA. How many miles can I expect to get on these before I should flip them?
Old May 1, 2010 | 01:54 AM
apro06g35's Avatar
plan on flipping them about every 7k miles.
Old May 1, 2010 | 02:30 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
5-7k.
I killed the inside of my 40k mile warranty all season Bridgestone RE960's in 7k. Alignment was done every couple months since i worked at the shop.
Old May 5, 2010 | 01:14 PM
saoLin413's Avatar
Thanks for the reply guys Would it make any difference if I adjusted it to 2.3 (max I can go without rubbing too much) then get alignment again or should I just leave it???
Old May 6, 2010 | 07:48 PM
Canadian G's Avatar
Are you running that much camber for performance or to avoid rubbing?
Old May 7, 2010 | 03:59 PM
saoLin413's Avatar
avoid rubbing!
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
Rose M
Oct 12, 2015 10:00 AM
