Ichiba spacer retorque?
Old May 3, 2010 | 10:15 PM
kenempireex's Avatar
I am installing my Ichiba V2 15mm and 20mm spacer for my 19"oem tomorrow. Assuming the shop install it right on the first time, how often should I check and re-torque the spacer? One of the shop people said I should re-torque it every 10,000 miles? Is it necessary?
Old May 3, 2010 | 10:19 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Re-torque it after 50-100 miles and you should never have to do it again. Then just have it checked when you swap out tires or get a rotation (side to side if you have asymmetrical tires)
This is the same procedure we use when installing new wheels/lug nuts at our shop.
-GP-
Old May 3, 2010 | 10:35 PM
-GP-
Yea....after I get it install tomorrow. They suggest me to go back and recheck.
Old May 3, 2010 | 10:42 PM
After that, you dont need to go back again.
Old May 5, 2010 | 12:00 PM
izeroi's Avatar
Yup. Same thing I did with mine and all is well.
Old May 8, 2010 | 09:44 AM
jasony0228's Avatar
Wut does it mean by Re-torque?
Old May 8, 2010 | 09:49 AM
Locksmith's Avatar
When you "re-torque" down the nuts it just means you basically re tighten all the nuts that hold the spacer on.
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
