New rims and Tire Pressure monitor
Old Sep 22, 2004 | 04:10 PM
g35sedan1027's Avatar
If you get new rims(other than stock) does the tire pressure monitor get messed up, does it work fine with the new rims, what happens?
Old Sep 22, 2004 | 05:35 PM
avs007's Avatar
Re: New rims and Tire Pressure monitor
The G35's tire pressure monitor is a module connected to the other side of the valve stem. Most likely your new rims, (if you are talking about aftermarket), will not have proper clearance for you to move the modules over.
GM for example, implements the low-tire pressure monitor as a mathematical algorithm in the PCM that calculates the average circumference of the tires, based on the abs sensors. When it detects that the average circumference has dropped it lights up the warning lights. This system is compatible with pretty much any rim you throw at it. It's drawback, is that it needs about 1-10 miles to determine if the tire is flat, and 20-100 miles to determine that a tire is merely low on pressure. The G35's sensors, report pressure every minute when in motion, I believe, so it's more "real-time".
<P ID="edit"><FONT class="small"><EM>Edited by avs007 on 09/22/04 02:36 PM.</EM></FONT></P>
Old Sep 23, 2004 | 04:08 PM
Good reply, thx! So then what are people doing with the tire pressure monitor when they get aftermarket rims, say 19" or 20"?
Old Sep 23, 2004 | 08:19 PM
metasystem's Avatar
04 G35 Coupe 6MT Gold Brembo’s
It usually means just going without the TPM system with the new wheels.
Some wheel designs might be able to accept the TPM sensor, in which case you could take the stock tires off the wheels, remove the TPM sensors, and use them on the new wheels.
Old Sep 24, 2004 | 12:17 AM
G2FAST's Avatar
Does any one have pictures of this system?
My 2004 G35
Old Sep 26, 2004 | 02:22 PM
Profile4's Avatar
i recently ran into this problem on my trip to baltimore from ny. after about 45 minutes of highway driving, the sensor light goes on. it is a bit annoying, but i just ignore it until i figure out wat to do with it.
04 DG/G/6MT/Premium/Nav/Clear Bra
Bone Stock...to be continued...
"You kill mah brodah, now I kill you!" - some old kung-fu flick
Old Sep 26, 2004 | 05:33 PM
MiamiG35sedan's Avatar
I don't get it. Some with aftermarket rims and no sensor say the light goes off, some say both the light and the buzzer, some say nothing happens. Isn't there just an easier way such as pulling a particular fuse?
2004 Sedan 5AT STS
Huper Optik Ceramic 50/Underbody Diffusers/Clear Corners/Brake Cover
GroundingGear 7 Wire/Z-Tube/Stillen High Flow Airbox/HKS Sport Exhaust/Technosquare F-Spec ECU
Old Sep 27, 2004 | 11:14 PM
THX723's Avatar
G Kreuzer
As long as the face of the modules lie relatively flat when mounted they will work just fine. Some aftermarket wheels have valve stems that stick straight up (at 90-deg. rather than ~45-deg.) ... those will not work properly, as there's a centrifugal switch inside the module that is activated only when the wheels generate enough speed. I've got them on my aftermarket wheels and the sytem works just as intended ... even tried to leak out the air below 26psi just to see if it trips the alarm ... and it sure did
One can also opt to not install the pressure sensor modules at all, but every once in a while, the low pressure warning light will illuminate (no buzzer) when the system does a periodic self test then goes away after some time. The warning light is not particularly annoying to most, however, since it's very small.
Clint (THX723)
vitamin.v
Nov 7, 2019 06:10 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Gip
Aug 24, 2015 05:31 PM
JoeMac
Aug 20, 2015 10:17 AM
