WTB: 10mm spacers with built in studs
Old Jun 13, 2010 | 02:14 PM
G2FLIP4's Avatar
everything
10mm and 15mm Project Kics spacers
Looking to pick up a set of 10mm spacers with the studs already in them(Project Kics). Also looking for a set of 15mm ones. Id prefer the 10mm ones first since Id like to throw them on the front and see if I can get away with 15mm on the front and 10s on the rear. Seen a few sets around, I know someone has to be selling some....
Old Jun 18, 2010 | 09:27 AM
G2FLIP4's Avatar
everything
friday bump
Old Jun 18, 2010 | 05:02 PM
P3R3Z's Avatar
Would u b interested in some 25mm? Unknown brand.
Old Jun 18, 2010 | 05:18 PM
G2FLIP4's Avatar
everything
no
10mm is pushing it in the rear and 15 is all im gonna be able to do in the front.
Old Jun 19, 2010 | 12:59 AM
UCIMAplaya2's Avatar
Just a warning, even if you could find some 10mm spacers like project kics with built in studs, they might not fit without modification. The recessed area in the wheel hubs that allow for the oem studs to sit into usually isn't deep enough with only a 10mm spacer, and won't let the wheel sit flat onto the spacer. So check that first.
Old Jun 19, 2010 | 12:19 PM
G2FLIP4's Avatar
everything
I work in a machine shop so any modifications I need to do can be done.
Old Jun 27, 2010 | 09:18 PM
bowzer's Avatar
Sent you a PM.
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
the93owner
Oct 4, 2015 09:40 AM
w4kj4k
Oct 2, 2015 07:57 PM
