Frankieg35
close
- Join DateOct 2006
- LocationSouth Jersey
iTrader Positive Feedback98
iTrader Feedback Score(41)
Liked:857 Times in 745 Posts
Do you have pics with the black and grey basecoat??
http://www.motostorm.com/hypersilver.html
I updated two of the wheel pictures to show the finish over a black base versus a light gray. 90% of our customers apply the Hypersilver over a black base.
Frankieg35
close
- Join DateOct 2006
O damn, thanks.. I think I'm going to do the black base with hypersilver.. Can u do any color black?? Matte, semi or gloss??
You will want to use a gloss black automotive urethane base for the Hypersilver. There are different methods to create a gloss black urethane base. (1) Black base coat/ 2K clear coat, (2) Single stage black 2K urethane or (3) black primer/2K urethane clear coat.
You are basically going to paint the wheels to look like a gloss black factory car finish.
Frankieg35
close
- Join DateOct 2006
What about powdercoating them gloss black then painting over that with the hypersilver?? I ask because I can powdercoat at my work and do I just need the 8oz can??
An 8oz bottle would work. It will need to be sprayed through an airbrush, detail gun, touch up or hvlp. The paint comes ready to spray.
Powdercoat will work. Either polyester or urethane gloss black powdercoat. After the hypersilver is applied you will want to topcoat it with a powdercoat clear, urethane automotive clear or a simple spray can clear coat(would be my last pick). I would just do a few small test panels before you tackle the wheels.
Frankieg35
close
- Join DateOct 2006
Thanks for your help, i cant wait to do this project in the spring..
Quote:
Your welcome. I can't wait for spring, this winter has been brutal up here in northern Ohio.Originally Posted by Frankieg35
Quote:
Too bad I don't have a G35 coupe anymore to get some rolling shots. I miss that car.Originally Posted by ChrisKG35
I wanna see rolling shots!! They look great!
Frankieg35
close
- Join DateOct 2006
Quote:
Same here.. Cold and snow.. Originally Posted by phsinvent
