Possible to go 235/50/17's all the way around '04
Old Jul 29, 2010 | 08:26 PM
JaE35's Avatar
Moderator
G35 Sedan
Title states it all, my fronts are feeling a little frail. I'm running the g35 couple 6 spoke alloys with 225/50 in the front and 235/50 in the rears. How would 235/50 sit in the front or is it even possible on the fronts without rub
Old Jul 29, 2010 | 09:04 PM
boostedforlife's Avatar
should fit okay, but better check if the tire is good,
the 245 45 17 i ran needed 8 inch wide so it was maxing out at that.
not sure about 50 series.
Old Jul 29, 2010 | 09:11 PM
JaE35's Avatar
Moderator
G35 Sedan
i got ya, those 45's are a little wider than the 50's right
Old Jul 29, 2010 | 09:33 PM
3truman's Avatar
no 45 and 50 is the sidewall size, not the width of the tire, that would be 235, 245, 255. a 235/50 on the front would only be wider than a 225 not taller
Old Jul 29, 2010 | 09:41 PM
yea, the 45 is not as tall as 50, but since it is not as tall the rim with makes a difference.
coupes are 7.5 wide in front and 8.0 wide in rear.
Taken from tireracks site on the dunlop starspecs
" 245/40ZR17
Load Index 91 = 1356lbs (615kg) per tire
Speed Rating “W” = 168mph (270kph) 91W SL Treadwear: 200
Traction: A
Temperature: A200 A A 1356 lbs.
51 psi
10/32"
26lbs. 8-9.5"
8.5"
9.8"
NA
24.7"
844
Country of Origin "JP" = JAPANJP
245/45ZR17
Load Index 95 = 1521lbs (690kg) per tire
Speed Rating “W” = 168mph (270kph) 95W SL Treadwear: 200
Traction: A
Temperature: A200 A A 1521 lbs.
51 psi
10/32"
28lbs. 7.5-9"
8"
9.7"
NA
25.7"
808
Country of Origin "JP" = JAPANJP "
The 245 40 need atleast 8 inch wide
the 245 45 can do it on a 7.5
Per tire specs its not safe to run anything wider, many have run one size wider and didn't die, but I rely on my tires so I wouldn't chance it. Sames for the other way for the guys with stretched.
Theyd put a 215 on a 8.5inch wide tire which it says not to do but they still do it.
Old Jul 29, 2010 | 09:47 PM
3truman's Avatar
Oh I see what your getting at. Bigger sidewall gives tire more room to play width wise, ie streching/oversize, I have the same wheels, coupe 17's
Old Jul 29, 2010 | 10:05 PM
well if it helps im running 24545 all around the starspecs...
but car is pretty low. lower than stock, (i had 235 45 18)'s stock. The price for a sticky tire is great, but clearance isnt that good and im not slammed
Old Jul 29, 2010 | 10:47 PM
NFSP G35's Avatar
? = 2B || !2B
Question belongs here: https://g35driver.com/forums/wheels-...-ask-here.html
Old Jul 30, 2010 | 05:01 PM
ntrinsik's Avatar
You shouldn't have any issues with rubbing.. I'm currently running 265 all around without issue.
Old Jul 30, 2010 | 05:07 PM
JaE35's Avatar
Moderator
G35 Sedan
Thanks a lot! I'm gonna throw some on this or next weekend
chicklet
Archived Sales
Feb 5, 2007 04:41 PM
749009
Nov 11, 2006 06:35 PM
mark5
Mar 29, 2006 03:10 AM
