Offset on G35
Old Apr 11, 2003 | 01:44 PM
maxboost's Avatar
Offset on G35
from what i used to know before about offset is there is the negative offset and positive offset.if u want to have the deepdish look u'll need to go with negative offset and vice versa for the positive. however after i read through a lot of web site for wheels and in this forum all i see is +20, +30, or +40 which i don't understand at all what those terms mean so i'm just thinkhing that someone could explain it to me and if u can also tell me how to convert it to those plus and minus system that would be great.
another thing, i was looking around to searh for wheels on sedan and i found this set
18*7.5 +40 fr and 18*8.5 +43 rr
what would this wheel look on the sedan (will it fill the wheel well)
Old Apr 11, 2003 | 03:14 PM
BillR's Avatar
Re: Offset on G35
They should fit fine. Here is a link to some 40mm offset wheels on my G35C. Should help you somewhat
https://g35driver.com/forums/showfla...sed&sb=5&part=
BillR
G35C Laser Red, Prem, Nav
Old Apr 11, 2003 | 07:54 PM
maxboost's Avatar
Re: Offset on G35
actually the specs were from Nismo GT4 wheels so it should fit no problem but what i really don't understand is what are all these numbers??? +20 +30 +40 could someone help straighten things out for me
Old Apr 11, 2003 | 07:59 PM
rajc007's Avatar
Re: Offset on G35
the positive offset is "x" mm from the center of the wheel towards the outside where the wheel bolts on.
This link should help
http://www.tirerack.com/wheels/tech/offset.htm
03 CB G35 Coupe 6MT
estimated arrival - 5/6/03
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
