bad wheel spacers??
Old Sep 1, 2010 | 08:56 PM
g35maraj's Avatar
bad wheel spacers??
i been searching for a set of wheel spacers, it looks like most here have 25mm front and back, question is , how long have u had them , how do u drive with them, ive heard stories of these things breaking, and putting strain on the axles hub, also most here are using icihiba? any input would be nice, this is for the stock 19 rays.
Old Sep 1, 2010 | 09:19 PM
herrschaft's Avatar
The older spacers with the separate studs were known to have problems. The Ichiba V2's are good and have the studs built in. Yes these will put more strain on the wheel bearings but this is a long term effect and not easily proven.
Old Sep 1, 2010 | 09:23 PM
g35maraj's Avatar
what i figured
are u running spacers? if so how many miles u have on them
Old Sep 1, 2010 | 09:27 PM
herrschaft's Avatar
I have 20/25mm spacers, only have about 3K miles on them and no problems so far.
Old Sep 1, 2010 | 09:29 PM
driver1712's Avatar
HERE ya go.
Old Sep 1, 2010 | 09:46 PM
herrschaft's Avatar
^Good find
No dude, dont worry about it, many have run spacers and for the most part our hubs can take the added strain no problem. bearings havent been failing left or right to warrant telling you other wise. Could a bearing fail........sure, weather it was the sole cause of a spacer........i highly doubt it...
Its funny because 2 of my hubs had to be replaced so far and thats before I put the spacers on (before 50K miles). Curious to see when they'll need to be replaced again.
Old Sep 1, 2010 | 10:40 PM
Xet's Avatar
Xet
I ran that setup on my oem 19's for over a year with no problems, built in studs or extended studs and you should be fine.
Old Sep 2, 2010 | 05:33 PM
Lionman51's Avatar
I just bought some 19 inch axis pentas. They are 8.5 in front and 9.5 in rear. They seem to be tucked in way more than my previous wheels. So im guessing I need spacers. What do yall recommend?
Old Sep 2, 2010 | 06:12 PM
irishsig's Avatar
Well I've had 25mm wheel spacers with my oem 19s for about 2 1/2 yrs and haven't had any probs.
For the past year my new job has me taking the canyons every day with no issues either.
In my research I found it was very difficult to actually find anyone that had personally experienced a wheel spacer's integrity failure.
Not saying it's never happened but I was comfortable enough after doing the research to go ahead with the mod.
It makes the car look 10 times better too.
Old Sep 2, 2010 | 09:26 PM
g35maraj's Avatar
icihbias spacers
icihiba spacers seem to be the top choice on this forum, the v2 version with the studs built in, if i decide to get them, it will be these, what do u think about used ones?
Old Sep 2, 2010 | 09:38 PM
driver1712's Avatar
^ i'd just pay the extra $30 - $40 to get new ones... peace of mind.
Old Sep 2, 2010 | 10:49 PM
Xet's Avatar
Xet
Perfectly fine, people have to post pics and as long as the thread are stripped, bolts not broken, spacer not cracked there really isn't too much more that could go wrong with the simple design of spacers.
Old Sep 3, 2010 | 01:03 AM
g35maraj's Avatar
thank you
good respones to make my mind somewhat at ease. looks like its a go...
Old Sep 3, 2010 | 01:07 AM
herrschaft's Avatar
Offsets?
Old Sep 3, 2010 | 12:42 PM
releasedtruth's Avatar
I've been running +25 H&Rs for nearly 2 years now, no problems on M45 wheels. Would like to try something new, however.
jsimonk
Dec 22, 2023 03:49 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
