Tire Size Help
Old Sep 7, 2010 | 10:13 PM
Almost_darkness's Avatar
Tire Size Help
Hey guys need some help with tire size for rears, I have an 03 G35 coupe, currently running 20x10 et35 in the rears, current tire size is 255/35/20 but blowing one tire i am looking at increasing the tire size, will 285/30/20 fit the rears without rubbing? I am on stock suspension as well. Any input or help would be greatly appreciated.
Old Sep 7, 2010 | 10:21 PM
RogerG35's Avatar
Why are you getting one with less sidewall? Your rims would be sticking out more, if anything it should be 285/40/20. Since your on stock, 285 should not rub
Old Sep 7, 2010 | 10:23 PM
oh sorry the reasoning behind the tire size is the deal i was getting, what is the most ideal tire, the previous setup had a lot of stretch on the rim and i am concernred that was the reason it blew in the first place
Old Sep 7, 2010 | 11:13 PM
RogerG35's Avatar
If your problem is the stretch, try increasing the 2nd number (its the sidewall width). My wheel in the rear is 20x10.5 on a 255/35/20 tire and im stretching it. Try 255/45/20?
Old Sep 7, 2010 | 11:19 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
no he should not be going with a 285/40/20 He should be going with a 285/30/20. You decrease the sidewall aspect ratio when you are increasing the width. The "30" or "40" number for the sidewall is a percentage of the width.
285/30/20 will fit without rubbing if you're stock, but the wheels will look like they are sticking out much more than the 255/35 you currently have because the tire won't be stretched anymore.
Old Sep 7, 2010 | 11:21 PM
You really need to read up on tire sizes and their nomenclature because you are giving horrible advise that can throw someones whole setup off.
Not trying to be a d!ck, but you should read this before giving tire advise.
http://www.tirerack.com/tires/tirete....jsp?techid=46
Old Sep 8, 2010 | 08:26 AM
Thanks for the advise guys so what is the most recommended tire size for the width of wheel I have? Keep in mind where I live the roads are terrible and I daily drive my G
Old Dec 27, 2010 | 01:34 AM
sorry to bump my old thread but i am still a little confused any insite would be greatly appreciated
Old Dec 27, 2010 | 01:59 PM
adrenaline rush's Avatar
With really rough roads, 20" rims are never going to be comfortable, no matter what size you go with.
That said the 255/35/20 size you went with is pretty close to the stock diameter, and if you want to go wider, the 285/30/20 size is a good size as well. Your sidewall on both tires are both about the same height though so the ride is going to be very similar. A 295/30/20 would also fit.
If you want to punch in some alternative tire sizes, try here:
http://www.miata.net/garage/tirecalc.html
Old Dec 27, 2010 | 02:14 PM
LightsOut's Avatar
SIETESG
275/35 tire would be best for you. It wont be a bulge like a 285 tire and you wont have any clearance issues, if you decide to lower your vehicle later.
Old Dec 27, 2010 | 05:52 PM
thanks for the input guys, i understand the ride will still be the same however i am curious as to which tire size will provide the least amount of stretch, i think that was my problem last time when my tire blew out.
Old Dec 27, 2010 | 06:06 PM
MixturePinoy's Avatar
anything wider than 255.
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
mryogi
Aug 14, 2015 07:58 PM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
