Spacers
Old Oct 13, 2004 | 06:59 PM
Daddylongstroke's Avatar
Spacers
I want to push my front rims further out. Maybe 'bout 20-25mm. I'm worried about not having enough length on the bolts to accomodate a spacer this thick. Anyone know where is the best place to buy spacers would be? Anyone on these boards using thick spacers? If so what kind?
Old Oct 14, 2004 | 01:10 AM
GoSooners's Avatar
Re: Spacers
www.optionsauto.com
I have a 15mm on my rear wheel that has a 35 offset
Black 5AT Coupe, Navi, Falken Koblenz 19", HKS Legamax Exhaust, ZTube/Stillen, Grounding Kit, RSR Springs, Tokico DSpec Shocks
Old Oct 14, 2004 | 05:34 AM
neffster's Avatar
Re: Spacers
I'd do some research on wheel spacers before I added 1 inch to any setup. There are pro's and cons to them, but from what I've read 1 inch seems like it's just too much. May want to consider a different set up...
Normally you have the wheel and the hub that put 5 bolts in double shear, with wheel spacers you have double-double shear and this is double trouble, especially if you're driving hard. There is more to it than just that, but there is a ton of information on the internet about wheel spacers. Do a search and post your findings.
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
