Offsets w/ no rolling required?
Old Sep 27, 2010 | 07:12 PM
Mre G Pilot's Avatar
I want wider tires so my stock 19" rays have to go. I also want a different ride so I'm going to get 18's. I'm driving a stock 2006 coupe 6MT.
I've decided to get the Enkei RPF1 (18x9.5 +15 and 18x10 +15). Has anyone installed these rims on a stock G coupe? I don't want to roll the fenders and I'm not going to lower it. I do have Rear Active Steer so i need to be careful about going too wide in the rear. I plan to put 255/40's up front and 275/40's in the back.
The other option would be to get the RPF1's in 18x9 +35 and 18x10 +38. But that is a totally different look. Do I need to go with that or will the +15 offset work w/o modification?
Thanks
Old Sep 27, 2010 | 08:01 PM
eric cartman's Avatar
I have 9.5 +15's and had to mild roll the rears, they may have been alright but close.
Old Sep 28, 2010 | 01:05 AM
Hmm. Sounds like I need to stay about +30 or larger to fit a 275 on a 10" rim. Thanks for your input. Any more input would be greatly appreciated.
Old Sep 28, 2010 | 01:14 AM
whoozyadaddy7's Avatar
I have 285's on a +15 10" rim and i had to do a mild roll as well, almost nothing. I would say on a 275 tire anything in the 20's offsets would be safe, you don't have to go to all the way up to 30's.
Old Sep 28, 2010 | 12:45 PM
darksideG35's Avatar
i run 18x9 and 18x10 with a +20 offset all the way around with 245/35 and 275/35 tires lowered on 350z gf210 springs and i do not rub at all and have no fender modifications done to my car. it is close, but with a little bit of negative camber you should have no problems.
Old Sep 29, 2010 | 10:18 AM
Thanks. For all the feedback.
obender66
18 Inch
Mar 13, 2016 12:20 PM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
Soumilg
Jul 18, 2015 12:33 PM
GSTG35
Mar 24, 2006 08:31 PM
