Rear Camber & Toe adjustment for only $90.00
Old Oct 21, 2004 | 10:08 AM
neffster's Avatar
Hey guys, check out this product. Apparently SPC sells camber and toe bolts for $90 for the rear end of our cars. This is much cheaper than the rear camber arm option.
Does anyone know what... "Adjustment slots will need to be elongated using rotary files..." actually means? Does this mean that we'd need to hack away at a stock part of our cars?
Old Oct 21, 2004 | 11:49 AM
Omi's Avatar
Omi
Charter Monkey Florida G35 club
From: on some Prius forum somewhere. Also getting 60mpg.
Re: Rear Camber & Toe adjustment for only $90.00
I would hazard a guess that that won't do the trick just by elongating one bolt. I don't see how you can affect Camber and Toe with just that. Of course I could be wrong
Old Oct 21, 2004 | 12:44 PM
PlatG's Avatar
I think the advertisment is misleading. I have the SPC toe/camber kit and it comes with 2 camber arms and 2 toe bolts. I'm guessing what the link points to is just for the toe bolts.
BTW, Todd, if your interested, I'm not going to use my SPC toe/camber kit since the dealership was able to get my alignment within spec. Let me know if your interested in it.
http://www.floridag35.com
Old Oct 21, 2004 | 01:12 PM
neffster's Avatar
Jeff, what are you doing today at 3pm? I'll be at Racing Zone. Give me a call.
What? You think that John Kerry is not consistent?
Old Oct 21, 2004 | 02:54 PM
THX723's Avatar
G Kreuzer
Neff,
Those camber bolts will indeed work very nicely. The only caveat is having have to open up the bolt hole via filing. It's not a drastic one that's likely to compromise structural integreity, however, but none the less you are cutting into ur baby.
Extra camber adjustment is not achieved via lengthening of the bolt. It is the 'cam' portion that has been made larger ... increasing the adjustable range. Think of it as running a camshaft w. higher lift porfile.
Clint (THX723)<P ID="edit"><FONT class="small"><EM>Edited by THX723 on 10/21/04 11:55 AM.</EM></FONT></P>
Old Oct 22, 2004 | 01:45 PM
nnkfws333's Avatar
THX723 is right, its in the cam of the bolt. I use ingulls or ingalls one before on my previous car. I would prefer control arms though.
S13/SR20 for sale
Old Dec 13, 2005 | 10:12 PM
MI SO FST's Avatar
I know this is a VERY old thread, but does someone have pics of how this looks installed. I am in need of a rear camber kit. Or any suggestions of how a good camber kit would work? I would like to be able to use the stock springs cups as well. Thanks and sorry for reopening this.
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
jimNC
Jul 25, 2015 05:47 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
