Official XXR Wheel Thread
#481
im my other G, i scrape in my drive way. pluss i'll be runnning 40 or 45 series tires, so it will fill up the wheel well
#482
for anyone with questions for the 526s... here are mine.
Front: 20x9 +15mm offset with 245 hankook v12s
Rear: 20x11 +35mm offset with 285 hankook v12s (shoulda went 275)
i have my rear fenders rolled and pulled. I have one fender with a bit of rust so it couldnt be pulled as much so i rub a bit... thats why i say i shoulda gone 275s in the rear. The side you are seeing i dont rub unless i whack a massive crater
and im also on greddy coilovers and at about 95% low. dont know the exact specs. and i have a little negative camber but i dont know exact alignement spec either. If anyone needs them tho i could make a call. hope this helps some ppl. More pics to come next weekend. Love these wheels!!!!
#484
You got the 20x11s with a +35mm offset? If yes, can I ask where you purchased them from. I was under the impression the 20X11's only came in +15mm
#485
and i have no good pics from the back... ill take some later and post them up
#486
UPPS maybe you are confuse or something but if they where 35 offset your wheel wouldn't be that flat in the middle, more like a concave look, maybe you thought about it but those are 15 offset, they haven't make 35 offset in those 20x11....i check everywhere and those are only made 20x11 +15 offset....if they where 35 offset it will probably hit the inner part of the fender (shock) because is not enough space that's why most of us run stretch tires...
#487
whoops... my bad guys i just rechecked my order. my offsets were backwards. 20x9 +35mm in the front and 20x11 +15 in the back. you are right they did not make 35mm offset for the 20x11s sorry for the confusion.
and yea you need to run a stretch in the rear. not crazy tho, unless thats what you are into. Like i said im running 285s in the back and on the side that the fender is rolled and pulled as it should be... i dont rub. Unless your looking for a crazy stretch i wouldnt go less then 275s.
#488
#489
are you lowered? bc i dont have spacers and im damn close to my fender as is haha and they are pulled. and yeah i see 255s alot, it gives you a bit more clearance but thats a good stretch and im from north Jersey... winters are not kind to the roads and that tire on that wide of rim could end up being a headache.
#490
#493
also here are some more pics from the back:
