Need help with tires
Old Nov 3, 2010 | 02:27 PM
LightsOut's Avatar
SIETESG
you should roll your fenders no matter what.. its best to be safe than sorry.
it's been awhile since I been configuring tire size and offsets for coupes. But shouldn't you be going with a less width tire... like 255 width?
I know at 10.5 wheel and 275 +13 is about perfect with fender roll. Now going +0 same width..
Do you have any camber kits to help pull negative camber in?
Old Nov 3, 2010 | 02:40 PM
Sp33dY's Avatar
No I don't do you think I should get one and what offset should I get if I dont want to get any cambers?
Old Nov 3, 2010 | 03:11 PM
LightsOut's Avatar
SIETESG
what offsets are offered? I don't remember. isn't +15 offered?
another question is how low do you plan on going?
Old Nov 3, 2010 | 03:18 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
If running the 285's you should roll the rear fenders for proper clearance.
Old Nov 3, 2010 | 03:21 PM
LightsOut's Avatar
SIETESG
since you plan on going with springs and not coilovers. I'd suggest not going with the +0 offset.
not being able to adjust the height, and having to adjust camber to a set height, is not worth the headache you might go through.
Old Nov 3, 2010 | 06:17 PM
iheartsny's Avatar
just fyi, +0 all around on stock height looks pretty lame.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
