Need help with tires
Old Nov 2, 2010 | 04:33 PM
Sp33dY's Avatar
Question Need help with tires
Hi everyone I am about to order these rims I found, love them. I wanted to know what tires size I would need rims sizes are
Front: 19×9.5 +0
Rear: 19×10.5 +0
Vehicle: Infiniti G35 Coupe
Finish: Matte Black
Thank you all
Old Nov 2, 2010 | 04:42 PM
Deepdiver's Avatar
depends if you want a the stretched look or not.
F:245-35-19, R:275-35-19 is a common setup.
Old Nov 2, 2010 | 04:50 PM
Sp33dY's Avatar
Could I do 285's in the rear? and would it me 285/30/19? or 285/35/19? I dont know much about tires lol
Old Nov 2, 2010 | 05:27 PM
Deepdiver's Avatar
yes, you could run 285's. But keep in mind if you plan to lower it, you'll likely need to get your fenders rolled.
Old Nov 2, 2010 | 05:48 PM
Sp33dY's Avatar
So 275's would be perfect with the drop??? thank you for the info very much.
Old Nov 2, 2010 | 06:43 PM
Sp33dY's Avatar
If I lower my car of DF210 springs what would be the best offset? +0 or something else????
Old Nov 2, 2010 | 06:52 PM
GR6RR's Avatar
springs? go coilovers!..
also, I dont think the 275 or the 285 tire will fit on the car with those wheel specs. try a 245 or a 255
and you need to roll fendors..
Old Nov 2, 2010 | 06:53 PM
GR6RR's Avatar
are you buying the varrosteins?
Old Nov 2, 2010 | 07:04 PM
Sp33dY's Avatar
Yes Varrstoen I really like the way they look matte black I don't really want to get coilovers maybe sometime next year but for now I want to do springs.
Old Nov 2, 2010 | 07:48 PM
GR6RR's Avatar
look up whats that dudes name... it was finallygotag...
now its johnnys_beast_foo or some chit like that..
check out his setup, I think he has the same plus spacers... then you could go from there..
Old Nov 2, 2010 | 07:49 PM
GR6RR's Avatar
dont know if this link works.... but here... a little searching and it can be found...
https://g35driver.com/forums/search....rchid=10526760
Old Nov 2, 2010 | 07:50 PM
GR6RR's Avatar
dont quote me on what I have said... cause I really dont know what I'm talking about
Old Nov 3, 2010 | 11:07 AM
Sp33dY's Avatar
So what kind of offset would you guys recommend?
Old Nov 3, 2010 | 01:52 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Could either run
245/35-19
275/35-19
285/35-19
Old Nov 3, 2010 | 02:18 PM
Sp33dY's Avatar
Originally Posted by neal@tirerack
Could either run
245/35-19
275/35-19
285/35-19
If I drop the car about 2" would the 285's b ok or I have to roll the fenders?
