Front wheel fitment on a coupe
Old Oct 21, 2004 | 06:29 PM
Import-Tooner's Avatar
Hey, I found some 19x8 RO_JA wheels for my car but the offset for the front is +25.. will it fit? The rears are going to be 19x10 with a + 45 offset. Thanks for your help.
Old Oct 21, 2004 | 06:55 PM
GoSooners's Avatar
Re: Front wheel fitment on a coupe
The fronts will fit fine. Stock wheel is 8" wide with a 30 offset. You may want spacers for your rear though since it's a 45 offset (tucked in more). 20mm or 25mm spacer should bring it out flush to the fender.
Black 5AT Coupe, Navi, Falken Koblenz 19", HKS Legamax Exhaust, ZTube/Stillen, Grounding Kit, RSR Springs, Tokico DSpec Shocks
Old Oct 27, 2004 | 04:55 PM
jaxxx's Avatar
the thingis even if you get spacers for your rear a 40+ offset wont give you much lip.....If you want the most lip you can get without rubbing I think 22 offset for the rear is the best way to go
Old Nov 21, 2004 | 08:41 PM
so.... Does a larger positive offset on the wheel make the lip smaller? I'm not too good with this stuff.
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
rping
Jul 26, 2015 09:53 PM
TheefrshstVQ
Jul 26, 2015 09:37 PM
djreinx
Jul 13, 2015 05:04 PM
