Help: Would Rim Size Conflict with Brembo Brakes??
Old Nov 16, 2010 | 01:58 PM
g35gizmo's Avatar
I am about to purchase these winter tires:
Bridgestone Blizzak LM-22 235/50R17 for Rear and
Bridgestone Blizzak LM-22 225/50R17 for fronts.
Since the rim size is 17" would it conflict with the brembo brakes? I want to buy them but want to make sure this is okay cause of the Rim Size. any help would be appreciated.
Old Nov 16, 2010 | 02:47 PM
Kuneff's Avatar
you will need a 3mm wheel spacer on the front wheels. I am running OEM 17's with ws60's for winter and thats what I have to do. If your 17's are aftermarket the spokes might clear the calipers, but you will have to throw the front ones on to see.
Old Nov 16, 2010 | 03:17 PM
g35gizmo's Avatar
Thanks for the response.
They are ASA alloy rim 17".
would they be okay with brembo? any help would be greatly appreciated.
Old Nov 16, 2010 | 03:32 PM
LordFappington's Avatar
The face looks like it can accomodate the calipers without spacers. 17's are ok for oem brembos.
Old Nov 17, 2010 | 02:34 PM
G35fromPA's Avatar
Those should fit w/o spacers. I run a set of 17x7.5 ASA JH3 wheels for winter on my '04 w/Brembos and they clear just fine.
Popes
Jul 29, 2015 05:07 PM
multimut
Canada
Jul 26, 2015 08:43 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
Karnicle
Jul 23, 2015 05:08 AM
vstypicals
Jul 20, 2015 10:55 PM
