19" G37S wheels on 03 G35 coupe?
Old Dec 4, 2010 | 08:50 AM
miketyler's Avatar
will they fit? I am running 18" 5 spoke 350Z wheels and while they have served me well I am looking for a change. Wheels look like these and are avertised as:
Front:
Wheels: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Tires: Bridgestone Potenza RE050A 225/45/19 92W. UTQG 140AA, weight 27 lbs., tread depth 10/32"
Rear:
Wheels: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Tires: Bridgestone Potenza RE050A 245/40/19 94W. UTQG 140AA, weight 30 lbs., tread depth 10/32"
Old Dec 4, 2010 | 10:45 AM
JAYRIPPA420's Avatar
yes they will fit. but for a more flush look ull need to run 25mm spacers front and 30mm rear.
Old Dec 4, 2010 | 10:48 AM
miketyler's Avatar
Thanks for responding. I never have liked spacers but sure do like the wheels. So no driveability, rubbing or steering issues with them and their backspacing as-is?
Old Dec 4, 2010 | 04:37 PM
miketyler's Avatar
Does anyone have pics of a G35 coupe withteh G37S wheels on it?
Old Dec 4, 2010 | 05:23 PM
first two pics without spacers...the third is with spacers.SORRY crappy pics
Attached Thumbnails 19" G37S wheels on 03 G35 coupe?-my-whip.jpg   19" G37S wheels on 03 G35 coupe?-024.jpg   19" G37S wheels on 03 G35 coupe?-004.jpg
Old Dec 4, 2010 | 06:10 PM
miketyler's Avatar
Thanks for those, I think it illustrates it very well. The 19"s seem to fill out the wheel wells better as well. Assume you are running the stock Potenza's? Did you have 18's previous? Any noteworthy changes in performance? Noise? Gas mileage?
Old Dec 6, 2010 | 03:03 PM
Deemo's Avatar
I have these on my car..I'm running 5mm on front to clear brembos though.
Here's them in stock color:
Then I painted them black:
Old Dec 4, 2013 | 07:05 PM
hfmt93's Avatar
I bought these and tried to put them on my 04 sedan. They would not go on all the way. The hub seems to be too big. Anybody have this problem? How did you fix it?
Old Dec 6, 2013 | 04:44 AM
Blue Dream's Avatar
I drove ttrank's car solo
Then you did something wrong, they fit just fine. Also make sure you get the lug nuts that go with them, they are different than the first gens.
Old Dec 6, 2013 | 09:53 AM
MikeDG's Avatar
Mine were a little hard to put on at first, so I had to take a wire brush to my hub to clean off some rust. Also make sure the wheel's mounting surface is clean.
Old Dec 6, 2013 | 11:21 AM
Diode Dynamics's Avatar
They look better with the spacer IMO.
Nice improvement over 18's
Nick C.
rezendvous420
May 31, 2020 01:26 PM
teamghost
Jul 28, 2015 04:52 PM
BlackGee35
Jul 23, 2015 01:36 PM
