Recommended Bolt On Spacer Size
Old Dec 11, 2010 | 07:44 PM
shazaam's Avatar
Hey Guys,
I'm picking up a set of used rims this weekend. The specs of the rims are:
Front: 19 x 8-1/2 Offset +46
Rear: 19 x 9-1/2 Offset +43
I was thinking about getting 25mm ichiba V2 hubcentric/bollton spacers. This would make my offsets: Front: 21, rear 18. I read other threads mentioning these are good ranges for an aggressive stance, but I'm not quite educated in whether the widths make a difference. Will i see potential rubbing with these spacers? I am not looking to roll my fenders.
I'm running a non brembo 2006 coupe
Old Dec 11, 2010 | 07:51 PM
CandlestickPark's Avatar
ill Sedan
If you want an aggressive stance then why aren't you planning to roll your fenders? You will not be able to run aggressive offsets unless you do so. Likely the info you saw posted for offsets in that range (upper teens) was referring to a 9.5/10.5 setup.
You should be looking for wider wheels (and lower offsets) for a Coupe. Even with spacers you would be 21mm front and 8mm rear less agressive than me and I have a Sedan.
Old Dec 11, 2010 | 08:09 PM
shazaam's Avatar
Let me rephrase then, what would be the recommended spacers to use to look as flush as possible without rolling my fenders for these 8.5/9.5 width rims
Old Dec 11, 2010 | 08:31 PM
erklep's Avatar
what size tires?
Old Dec 11, 2010 | 08:57 PM
the_sedan's Avatar
those are weak azz sizes. you dont want rims anything over +20 IMO for a good start.
Old Dec 11, 2010 | 09:09 PM
shazaam's Avatar
Originally Posted by erklep
what size tires?
the front with width 8.5" are 245
the rears with width 9.5" are 275
I'm choosing between a 20mm spacer vs. a 25mm spacer.
Old Dec 11, 2010 | 09:17 PM
B_Lam's Avatar
With your high offsets and small widths... i don't think it's possible to make them flush. If your offsets were lower and with the same widths... then yeah maybe it's possible. i don't think you need to worry about rolling fenders with those specs. you should just sell these and pick up 9.5/10.5 atleast...
Old Dec 11, 2010 | 09:49 PM
the_sedan's Avatar
i had 18x9/10 +20 with 15mm spacers with 235/40 and 265/35 and they were pretty flush with no rubbing dropped on df210 springs.
Old Dec 21, 2010 | 07:53 PM
05slateg's Avatar
I have 20mm in F & 25mm R
Old Dec 22, 2010 | 10:46 AM
adamls2's Avatar
i also haz df210 with 25mm all round with the OEM 19"s and 245F and 275R tires...front is fine but def need to roll fenders in the back :/
jsimonk
Dec 22, 2023 03:49 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
