0 offset question...noob
Old Dec 16, 2010 | 01:27 AM
jcherb686's Avatar
Looking into the varrstoen 2.2.2 in 19x9.5f 19x10.5r...would a zero offset be to much?
I have an 05 coupe lowered on tein springs...please help
Old Dec 16, 2010 | 01:30 AM
TIAN's Avatar
Hold The Line
Roll the fenders and add - camber and you'll be fine. Check this thread out:
https://g35driver.com/forums/wheels-...-ask-here.html
Old Dec 16, 2010 | 01:48 AM
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
Because this is your first post, I will help you a bit. I'm feeling nice.
0 offset all around will essentially make it look like this. This is Chris's car, from Downey, CA.
Natural camber with his set up, no camber kits or anything. You will need to have your rear fenders rolled with that set up tho, no questions about it.
Old Dec 16, 2010 | 05:08 AM
jasonseoguam's Avatar
chris is running that low without a rear camber kit?
Old Dec 16, 2010 | 05:56 AM
Im actually lower now ^
And no kit for Now
Old Dec 16, 2010 | 12:03 PM
Blackedout's Avatar
If you really want poke and are gonna be fine with camber tire wear get +0, I went with the +12s so I wouldn't have to worry about it that much.
Old Dec 16, 2010 | 12:18 PM
jcherb686's Avatar
Thanks for your guys...ill post pictures once its done
seagrasser
May 3, 2022 09:43 AM
Picture Share
Feb 4, 2018 12:41 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
TurTLe*
Sep 29, 2015 01:43 PM
