Tein Basic vs. H-Tech for 350Z
Old Oct 28, 2004 | 01:19 PM
skysky's Avatar
These two items might be discussed before, but I am only be able to find the spec. on both......Anyways, anyone know what's the stiffness difference btw the Tein Basic and the 350Z H-Tech??
I know the H-Tech is a lot cheaper than Tein Basic, and still there are many ppl who appreciate the Z H-Tech very much!! So just wondering:
1) Will there be anything bad to the car, if I using the H-Tech for Z on my G coupe??
2) Compare to Tein Basic, how's their stiffness differences? Just a bit?
3) Is the S-tech for G, lower than /or stiffness than, the H-tech for Z?
Thx for all advices!
Old Oct 28, 2004 | 11:06 PM
skysky's Avatar
Re: Tein Basic vs. H-Tech for 350Z
Anyone??
Old Oct 29, 2004 | 02:14 PM
ZeroGen's Avatar
Omega Enthusiast
Here's a breakdown:
H-Tech springs
Infiniti G35C spring rate (lbs/inch): 325 F / 263 R
drop (inches): 0.6 F / 0.3 R
350Z spring rate (lbs/inch): 358 F / 375 R
drop (inches): 0.3 F / 0.2 R
S-Tech springs
Infiniti G35C spring rate (lbs/inch): 358 F / 274 R
drop (inches): 1.2 F / 0.9 R
350Z spring rate (lbs/inch): 386 F / 402 R
drop (inches): 0.7 F / 0.6 R
Tein Basic
Infiniti G35C spring rate (lbs/inch): 503 F / 503 R
adjustable drop (inches): 1.5 F / 0.9 R - suggested
350Z spring rate (lbs/inch): 503 F / 503 R
adjustable drop (inches): 1.0 F / 0.8 R - suggested
If you plan on getting the Tein springs, I would suggest going with an adjustable (damping) aftermarket shock. If you used the stock shocks, who knows when they'll end up going because of the higher spring rates. The drawback with going with the springs is that you won't be able to adjust the height of the drop.
04.5 G35C TB/Graphite 6 speed, XM Radio, Premo Package, Navi, OEM Chin Spoiler
Old Oct 29, 2004 | 11:11 PM
skysky's Avatar
I think I'll go with shocks, rather than just springs because this may cost me cheaper in long-term.
A frd of mine just told me that his stock shocks was end up after lowering w/ spring in a year and three months!
Old Oct 30, 2004 | 01:04 PM
ZeroGen's Avatar
Omega Enthusiast
More info to my previous post:
Tein CS - MSRP $1760
Infiniti G35C spring rate (lbs/inch): 391 F / 391 R
adjustable drop (inches): 1.0 F / 0.7 R - suggested
350Z spring rate (lbs/inch): 391 F / 391 R
adjustable drop (inches): 0.4 F / 0.8 R - suggested
Tein Flex - MSRP: $1860
Infiniti G35C spring rate (lbs/inch): 671 F / 671 R
adjustable drop (inches): 1.5 F / 1.0 R - suggested
350Z spring rate (lbs/inch): 671 F / 671 R
adjustable drop (inches): 0.9 F / 0.8 R - suggested
If you plan on getting the Tein springs, I would suggest going with an adjustable (damping) aftermarket shock. If you used the stock shocks, who knows when they'll end up going because of the higher spring rates. The drawback with going with the springs is that you won't be able to adjust the height of the drop - some shocks may have some height adjustment with the lower spring perch; not all shocks have these, at least for the fronts on the G. With the full coilover setup, height can be adjusted. Tein Basics & CS only adjust for ride height whereas Flex can adjust for spring pre-load, ride height, and damping. For ride comfort, the CS would be suggested. If you're a performance oriented driver, then I would go with the Flex (if you can afford) or the Basics.
Also, if you wish to drop your car more than ~0.7 inches, I would suggest getting a camber kit. There are a couple of places that manufacture camber kits: 350evo, Performance Nissan, and Kinetix. Keeping the stock rims is no problem when lowering your car.
For me, I'm planning on going with the Tein Flex w/ EDFC & 350evo camber kits once I finally decide what rims to get. Install should be easy for full coilover & camber kits with the only thing I'd have to pay for would be the alignment.
Keep in mind, I only focused on Teins but there are so many full coilover setups out there: HKS, JIC, Zeal, Ohlins (expensive!), etc. Bang for the buck, you can't go wrong with Teins. Good luck with whatever set up you get!
04.5 G35C TB/Graphite 6 speed, XM Radio, Premo Package, Navi, OEM Chin Spoiler, Hard wired V1
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
DRG35R
Jan 31, 2016 07:14 AM
Learned Hand
Oct 1, 2015 09:02 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
