Fitment Experts Help Please
Old Dec 29, 2010 | 04:23 PM
mtv39's Avatar
Hey guys I've been in the hunt for some new wheels this upcoming spring and was wondering if I could get some advice from the experts.
Wheels: XXR 521 Silver w/ Polished Lip 18x10 +25
Suspension: Form and Function Type 2 Coilovers
http://www.robearracing.com/pd-funct...-g35-03-07.cfm
Rear fenders have a mild roll right now. I know I am going to need more work done. If anyone can give me some suggestions on a setup (Camber to run, tires, spacers, and fenderwork) I would appreciate it. I would like to get a poke out of these rims and try not to run super aggressive camber.
Thanks guys!!
Old Dec 29, 2010 | 04:32 PM
CandlestickPark's Avatar
ill Sedan
All the info you'll need is in this post...
https://g35driver.com/forums/media-s...-xxr-521s.html
Originally Posted by Gdup35sedan
I've had a bunch of people ask for pictures of the new setup so here they are!
Specs:
Front Fender to Ground: ~23.75"
Rear Fender to Ground: ~25"
Suspension: Stance LX+ Maxed out up front without removing the pre-load. Rear has 4 threads left.
Wheels:
XXR 521 18x10 +25 (10mm spacers all around) Effectively +15
Tires:
225/40 Yoko S-Drives up front
225/45 Dunlop SP Sports out back
Lugs:
Project Kics NeoChro
Grant's fenders are pulled ~5mm front and rear. -1.5 Camber up front -3 in the rear. This is the best 18s setup we've seen on a G Sedan for sure.
Old Dec 29, 2010 | 05:19 PM
Blue Dream's Avatar
I drove ttrank's car solo
Close this thread down, Marcus FTW!
Old Dec 29, 2010 | 05:20 PM
G SEDAN's Avatar
grants setu is so sick. love the gold rivets
Old Dec 29, 2010 | 06:52 PM
ill Sedan
Bwahahaha, I'm going to wait to see if the OP has any additional questions.
Old Dec 29, 2010 | 07:03 PM
Blue Dream's Avatar
Still, what a coincidence OP asked about the exact same wheels that Grant's running (except Grant's are black).
Old Dec 30, 2010 | 12:51 AM
mtv39's Avatar
I have seen that thread and studied it multiple times. That is where I fell in love with the wheels! The reason I made a thread was because I know that Grant is running spacers front and back on his and I believe he will be 1/2 inch lower than I would be on the Form and Function coilovers. If I'm correct...which I may not be, he's dropped 4" and the F&F only go 3.5" (correct me if I'm wrong).
If I can get away without having to pull the fenders and just rolling them flat that would be ideal. This is why I asked for some spec possibilities because of the slight differences (height and spacers). Thanks again guys!
KruZZe
Feb 27, 2023 05:04 PM
the93owner
Oct 4, 2015 09:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
DRG35R
Sep 16, 2015 05:33 AM
