275/35/19 vs. 275/30/19
Old Jan 18, 2011 | 07:26 PM
carboy19's Avatar
i just recently purchased my rims
fronts will be 19 x 8.5 offset is 15
rears are 19 x 9.5 with offset of 15 also
for the front tires, looking at 245/35/19... should i even consider 235/35??
and for the rears, i was thinking 275/35 but ive seen a lot of people going with 275/30 instead....
if the front tire height is 35...why get 30 for the rear? im a little confused..will that look unever..sine the front tires will be a little taller?
Old Jan 18, 2011 | 08:20 PM
4D05G35's Avatar
With the 245/35 and 275/30 you are looking at a sidewall difference of about 3mm between the two, with the front being the larger.
With 245/35 and 275/35 you are looking at a sidewall difference of about 10mm with the rear being the larger.
With 235/35 front your overall diameter will be about 25.5" and either of the rears will be about 26.6 for the 275/35 and 25.5 for the 275/30.
So as you can see, running a 35 series up front and 30 in the rear nets aout the same overall diameter, but with one being wider. Thats why the difference.
With the 245/35 and 275/35 it closely matches the diameter difference F-R that the coupe comes with from the factory (225/45/18F 245/45/18R)
Old Jan 18, 2011 | 10:27 PM
carboy19's Avatar
Thanks man!!!
Old Jan 19, 2011 | 03:29 PM
4D05G35's Avatar
You're welcome.
Old Jan 19, 2011 | 03:31 PM
06g35meister's Avatar
get the 35 profile, vdc wont freak out as much and youll have more sidewall to keep them quieter. Plus they just look like beasts.
Old Jan 20, 2011 | 05:08 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
+1 for the 245/35 and 275/35 combination.
Old Jan 21, 2011 | 02:01 PM
Henry_G35's Avatar
You can always just switch that annoying kid off
jsimonk
Dec 22, 2023 03:49 PM
KruZZe
Feb 27, 2023 05:04 PM
Depravity
19 Inch
55
Oct 16, 2015 01:36 PM
mryogi
Aug 14, 2015 07:58 PM
