will this fit
Old Jan 31, 2011 | 09:26 PM
007JD's Avatar
will this fit
S22 Wheels 20x8.5 and 20x10. Wheels come 5x114.3 with a 25mm offset in the front n 40mm in the rear
will this fit . 04 Sedan
http://i196.photobucket.com/albums/a...2a935a1dad.jpg
Old Jan 31, 2011 | 09:30 PM
O HELLA OEM's Avatar
thats what she said.........
but in all seriousness +25 offsets are pretty low for sedan offsets, these offsets are more geared to g35 coupes. but these will fit your sedan with smaller tires and i believe negative camber, someone correct me if im wrong
Old Jan 31, 2011 | 09:32 PM
Get_some35's Avatar
are you lowered?
Old Jan 31, 2011 | 09:34 PM
Matzo Ball's Avatar
how low are you? On coils or springs? You can fit them with stretch, camber and some fender work. The front should be just fine. Rears will require a flat fender roll and maybe a pull. 8.5 +25 front is where I am at now on a 225/40. But I am going to +20 to be perfectly flush once I go lower.
Old Jan 31, 2011 | 09:44 PM
007JD's Avatar
im not lowered yet.. stock hieght with sport package. shocks
im tryin to get tein flex coilovers
Old Jan 31, 2011 | 09:53 PM
SN00P's Avatar
CLUB MODERATOR
i have a 8.5 + 20 245/35 and im not flush... ^ go to +15 like kenny .. thats pretty close..
OP look for different wheels :-)
Old Jan 31, 2011 | 10:56 PM
007JD's Avatar
so dont buy these?
Old Jan 31, 2011 | 11:33 PM
CandlestickPark's Avatar
ill Sedan
Those will fit with no prob. Roll your fenders in the rear you'll be good to go.
I haven't heard great things about Sevas though, I would do some research on their quality prior to buying them.
Old Jan 31, 2011 | 11:45 PM
007JD's Avatar
i would have to roll b4 putting them on .
or roll them if i drop ??
and if i get them
can i drop , and if i do what i would have to do
Old Jan 31, 2011 | 11:54 PM
ill Sedan
I would have the fenders rolled prior to installing the wheels just in case it rubs. At stock height you shouldn't rub, but I've heard of people rubbing at stock height on Coupe 19s so its best to roll them first versus having a rubbing issue and needing to take care of it immediately.
Old Feb 1, 2011 | 01:49 AM
4DGS's Avatar
Why did anybody even ask if he was lowered?
Yes they'll fit no problem and with correct tire sizes won't even rub.
I suggest you roll the fenders on any car just because straight fenders are ghey
But really, I'm astounded, why did you guys even ask???
Old Feb 1, 2011 | 01:50 AM
bluedevils95's Avatar
i believe it will fit. just try time out. you can always take it in and do a test fit. That's what i did w/ my wheels
Old Feb 1, 2011 | 01:53 AM
kennymo's Avatar
those will definatly fit. my offsets are lower than that with the same widths.
Old Feb 1, 2011 | 02:39 AM
socialconflicts's Avatar
those wheels are fugly *** hell. sorry
Old Feb 1, 2011 | 02:59 AM
xxxxxxxxxx's Avatar
^^^+1000000000000000000000000000000000000000000000 0000000
