soo i want to go 18x10 all around too
Old Feb 21, 2011 | 10:47 PM
  #46
Gdup35sedan's Avatar
ENVautoDetailing.com
Originally Posted by xxxxxxxxxx
ok, and the rims come with a +25 offset , you have 10mm spacers all around, but you think they would fit with a 15mm spacer in the rear? i at least want to change something on this setup and not be identical to yours lol
You could do a +10 in the rear with a 225/45 and a little more camber.
If you don't have a front camber kit up front you'll need a 20-25mm spacer to flush it out with. 225/45 tire. If I were you, I'd go with a 15mm spacer and run a 235/40/18 up front. In the rear,
run a 10mm spacer with a 235/40/18.
This is all assuming your going to drop the car 3.5+ inches running atleast -3 camber all around.
Like Blain said, we can only help you so much. Every car is different and what works on one won't work with the other. Remember that my front and rear fenders are pulled as well.
Old Dec 28, 2011 | 05:46 PM
  #47
Canadiotica's Avatar
vurry niceee
auto_drive
Mar 28, 2004 01:22 PM
stevedg35
West
Dec 20, 2003 01:12 AM
