Tire help please
Old Mar 21, 2011 | 03:59 PM
poMx's Avatar
Tire help please
I have an 04 g35 coupe and I am due for some new tires. I was considering getting a wider tire in the rear. what do you guys recommend? I'm keeping my stock wheels. I am currently running 245/45-18.
Old Mar 21, 2011 | 05:18 PM
4DGS's Avatar
Going much wider is a little hard since the stock wheels are only 8" wide.
You could do a 255/45 but I personally would not mount anything wider than a 255 or it will start to bulge over the side of the wheel.
Old Mar 22, 2011 | 12:50 PM
McLaren23's Avatar
i concur
Old Mar 22, 2011 | 03:19 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Yup, the 8" wheels is the G35 curse. Not much you can do w/out buying new wheels. The 255's are a bit tight and aren't really the right diameter either.
Old Mar 22, 2011 | 10:41 PM
poMx's Avatar
So what would be the issue if I ran 275/40-15 in the rear?
Old Mar 22, 2011 | 10:42 PM
poMx's Avatar
275/40-18*
Old Mar 23, 2011 | 01:00 AM
4DGS's Avatar
It would look stupid as **** and be ugly. It would bulge over the edge of the wheel and might actually have a hard time staying seated....
I unmounted a 255/35/18 today from an 8" wheel and it was starting to stick out past the lip. Don't go wider than 255/35 on an 8. If you want to go more aggressive you need new wheels.
Old Mar 23, 2011 | 01:03 AM
redpearl99's Avatar
yea 275 is definitely a bad idea
Old Mar 23, 2011 | 03:34 PM
4D05G35's Avatar
There is a pic in the pic section of a coupe running a 275/35/18 on stock wheels.
It doesnt look right.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
