Need Some info & Help with Wheels
Hey guys...i'm new to the site and need some help with buying wheels, I have a 07 G35X Sedan and trying to buy 18" staggered wheels for the car, but some people are telling me that because its a X that i have to have all the rims the same size. Also something about the TPMS. Please help with some info. The Car is dropped on Eibach Pros.
The rims im trying to get are the 18" XXR 006
Staggered
18x8.5 Front
18x9.5 Rear
35 Offset
They Also come in
18x7.5
5x114.3
42 offset
18x8.5 All Around
35 offset
Someone please help me with Info and Tire sizes
Staggered
18x8.5 Front
18x9.5 Rear
35 Offset
They Also come in
18x7.5
5x114.3
42 offset
18x8.5 All Around
35 offset
No, you just need to keep the diameter within 3% difference of each other.
TPMS is tire pressure monitoring system. No worries there, they are just your factory valve stems. You get a warning light if they aren't in the wheels.
Id go with the 18x8.5 so your can rotate your tires.
But if you do want to stagger that's not a problem. You could run 225/45 front and 245/40 rear if you wanted to.
Thanx
Im thinking about doing the same but on my 04 coupe
The rims im trying to get are also 18"
Staggered
18x8.5 Front
18x9.5 Rear
35 Offset
and Im going to try and run 225/45 front and 245/45 in rear, or should I do 245/40 in the rear?
Staggered
18x8.5 Front
18x9.5 Rear
35 Offset
I would look for wider wheels 8.5" - 9.5" front and 10" - 10.5" rear and look for offsets in the high teens to low 20's to get a nice clean conservative look.
If you dont see something you like, I'm sure they can help you with what you are looking for.
vstypicals
Jul 20, 2015 10:55 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
