Need recommendations on spacer size
Old Apr 28, 2011 | 02:11 PM
Deemo's Avatar
Hello, so currently I have only 15mm spacers in the rear on my car. But I'm wanting to make it as aggressive as I can. My specs are 19x9.5 +19 245/35/19 and 19x10.5 +24 (+15mm spacer so effective offset is +9) 275/35/19. I'm also running -2.1 camber in the rear. So you guys think I can move the rear spacers to the front and then buy 20mm or 25mm spacers for the rear? Or would that rub alot? I have the rear fenders rolled flat. Also, I plan on getting coils over the summer to lower it a little more...
Please lmk ASAP as I've found a couple of good deals on spacers.
Here's some pics for reference:
Old Apr 29, 2011 | 11:25 AM
Deemo's Avatar
Bump. Anyone know?
Old Apr 29, 2011 | 03:16 PM
InfinitJazz's Avatar
Looks pretty flush already, if you replace it with thicker spacers, you will hit the fender irregardless of it being rolled unless you run narrow tires and go stretched on those rear wheels.
Old Apr 29, 2011 | 03:22 PM
Deemo's Avatar
Next time around when I need new tires I was going to go ahead and run a stretch. But I bought these tires no too long ago...so it's probably best to just wait till then and then decide?? Also will probably be getting coils around that same time.
Old Apr 29, 2011 | 03:53 PM
4D05G35's Avatar
I would think that you could do another 5mm front and rear, but not much more without rubbing. I would wait until you get the coilovers and new tires. You can go further with a little stretch + being lower.
Wanna sell those 15mm spacers?
Old Apr 29, 2011 | 04:04 PM
irishsig's Avatar
+1^ Get the coils & tires 1st.
Personally I think the rears are perfect,
the fronts could maybe use 5mm spacers to be perfectly flush with your current setup.
Are u going to be running 30 series tires?
Might want to make sure you're going to be cool with that rough of a ride before dropping the cash.
Old Apr 29, 2011 | 04:19 PM
Deemo's Avatar
Nah, I'm keeping the 15mm in the rear for now. Thanks for the help. I'm just going to wait till I need tires again
Old Apr 29, 2011 | 04:36 PM
4D05G35's Avatar
On the plus side, it looks good as it is.
Old Apr 29, 2011 | 04:40 PM
Deemo's Avatar
Thanks man!
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
