Stock 19"s...will a 255/35/19 work?
May 18, 2011 | 10:51 PM
Hey guys, I'm getting new tires on my 19's, I've decided on a 245/35/19 for the fronts, but I can not get a definitive answer as to whether or not the 255/35/19's will work on the rear, or will I need to go with the 255/40/19 to get the VDC and abs to stay sane?
I looked through the end all be all thread, but there were mixed answers as to if the 255/35's will work or not.
Please let me know guys, thanks!!
Reply 0
May 18, 2011 | 11:33 PM
You can run that if you want, but I'd suggest a 235/40 for the front.
Reply 0
May 18, 2011 | 11:44 PM
Quote: You can run that if you want, but I'd suggest a 235/40 for the front.
I forgot to mention, I have a coupe. If that even matters, lol.
Reply 0
May 18, 2011 | 11:52 PM
Not really lol
I ran that set up on my Z last year. (but 18s and track wheels)
Reply 0
May 19, 2011 | 12:15 AM
Nice, I wanted a Z pretty badly, but I went with the G instead, more seating ftw.
Btw, i meant to put 245/35 in the op.
Reply 0
May 19, 2011 | 02:06 AM
Quote: Hey guys, I'm getting new tires on my 19's, I've decided on a 245/35/19 for the fronts, but I can not get a definitive answer as to whether or not the 255/35/19's will work on the rear, or will I need to go with the 255/40/19 to get the VDC and abs to stay sane?
You should be fine - the rears are still larger in overall diameter than the fronts. It's only when you get the fronts larger than the rears that you run into issues.
Reply 0
May 19, 2011 | 03:02 AM
Those sizes will work fine and won't trigger any VDC problems. 245/35 and 255/35 is my current and favorite size set-up.
Reply 0
May 24, 2011 | 12:55 PM
Question to anyone: Does the aspect ratio of the tires have to be the same?
Reply 0
May 24, 2011 | 02:00 PM
^ no but the % difference has to be within 4% to keep the vdc happy
Reply 0
May 24, 2011 | 03:10 PM
Yes you can, I'm running 245/255x35x19 with no issues.
Reply 0
May 24, 2011 | 07:26 PM
Quote: Yes you can, I'm running 245/255x35x19 with no issues.
Are your rear rims wider?
Reply 0
