Need advice on new rim size/offset
Old Jun 1, 2011 | 11:39 PM
Rusty RAY'S's Avatar
Im think of buying some rims
Old Jun 1, 2011 | 11:48 PM
DrewDrew's Avatar
there won't be any stretch with a 255 on a 9.5. a 285 on an 11 won't necessarily be a stretch, but it won't protect the rim from curb either.
the front will be nice, it'll be flush with a 5mm spacer to get an idea. the rear will have some poke and needed camber to fit if you're lowered.
it'll look good no doubt. just make sure your fenders are rolled too.
Old Jun 2, 2011 | 02:05 AM
4DGS's Avatar
If you want to stretch you're going to want some spacers so the stretch isn't for no reason.
If it were me... I'd go 235/35 and 265/35 (these sizes however depend on the brand of tire you pick)
Then add a 15mm spacer to the rear 20mm spacer to the front lower the car 2.5-3" and let the camber do the rest.
Old Jun 2, 2011 | 10:54 AM
thanks guys!
Old Jun 2, 2011 | 11:13 AM
gary c's Avatar
Rusty you can run 245s on the front, that's large enough with your rim size. The 285s will work great out back. I do canyon runs with the same size rims with 245F and 275R without any issues....
Gary
Old Jun 2, 2011 | 11:22 AM
Gary
Thanks Gary!
I assume your running similar offsets correct? are you at stock camber aswell?
Old Jun 2, 2011 | 11:57 AM
4DGS's Avatar
So why the hell did you want a little stretch?
The 285/35 is one tall fkin tire.
Old Jun 2, 2011 | 12:19 PM
chill man, thats what i like im just looking for a tight fitting look. everyone has different tastes. and i want to match the same diameter as a stock rear tire aswell.
Old Jun 2, 2011 | 03:09 PM
4DGS's Avatar
The explain what "tight and fitting" is. Because stretching may be tight but it is my no means fitting.
Not sure what kind of track driving you do but unless you're drifting there is no point to stretch and your track set up should be as much tire on the ground as possible. Bad enough you're tracking 19s.
Old Jun 2, 2011 | 09:39 PM
[QUOTE=4DGS;5912391]The explain what "tight and fitting" is. Because stretching may be tight but it is my no means fitting.
Rose M
Oct 12, 2015 10:00 AM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
Learned Hand
Oct 1, 2015 09:02 AM
