Inner wall cracked...
Old Jun 2, 2011 | 06:29 AM
jin22gt's Avatar
I have the Dunlop sp signatures in 215/55-17 on my stock 17".
I have a sedan which is lowered.
All four tires has cracks on the inner side walls. Cracks are 1-7 inches long, all around. What would cause these cracks? I brought these tires in 12/2009. Got around 20k miles on them. I still have a little bit of treads left.
Any body else experience this b4? It seems very dangerous.
Old Jun 2, 2011 | 07:32 AM
infinitig35's Avatar
I think with 20K miles, those cracks are normal wear. Since your car is also lowered, it can be harsher on the tires.
Old Jun 6, 2011 | 03:14 PM
4DGS's Avatar
I wouldn't call it normal wear.
Check the manufacture date on the tire, it will be a few numbers in a smoother round block on the sidewall. It's usually set up as xxxx first 2 xs are the week of production and last two are the year. IE 0811 would be the last week of Feb.
Old Jun 7, 2011 | 05:58 PM
jin22gt's Avatar
Hey guys.,
It's amazing how these tires are all cracked on the inner part of the wall. I think it might be a problem with the tire material. I asked around, people are saying that the inner wall shouldn't be cracked like this because the car is lowered. It should only affect the tire treads area, if my camber or toe is out of wack.
I will contact the tire manufacturer and ask for some sort of reimbursement. Hope they give me at least a little bit.
I do have 19" tires and rims waiting for installation this weekend.
Here are some pics of the cracked inner wall. I just took pics of couple of wheels but every 4 corner has this problem.
What do you guys think..???
thanks..
Old Jun 10, 2011 | 01:47 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Sounds more like impact damage. Shorter walls/rough roads and it does not take much to damage a tires inner liner. Time to replace them, doubt the tire company will consider it a warranty issue. I would take them to a shop that carries the brand they are for inspection. If warrantable all can be taken care of on the spot, if not then it's time for a replacement(s).
yosip1115
16
Sep 28, 2015 04:14 PM
baker2795
Sep 2, 2015 06:00 PM
Spartan268
Aug 20, 2015 09:14 PM
EliteG
Engine - Electrical
Aug 5, 2015 07:50 PM
