Vibration after 19" installed.
Old Jun 24, 2011 | 05:15 AM
jin22gt's Avatar
Hey guys.
I just got my new 19" tires/ rims installed. Had the roadforce balanced.
I'm getting alot of vibration when I accelerate pass 50-60mph. But when I just cruise without pressing the gas pedal there is no vibration. What could cause this problem???
Also my front axle is messed up. The passenger side boot is torn up. Can this be the problem?? I didn't feel any vibration with my stock rims.
Old Jun 24, 2011 | 04:04 PM
350zspl's Avatar
are you using hub rings?
are the wheels dynamic balanced?
are you running spaecrs ?
Old Jun 24, 2011 | 06:01 PM
DogStar's Avatar
hub rings is my guess but I'd think you'd notice that well before 50.
You get a harsher ride on larger wheels in general as a switch from the 18s.
Old Jun 24, 2011 | 09:40 PM
jin22gt's Avatar
Im not sure if the shop used a hubs ring. They did the road force balance. Also my axle is kinda of messed up. Could this be causing the vibration? I didn't feel much vibration with my stock 17".
Old Jun 24, 2011 | 10:12 PM
toro12's Avatar
20 Year Member
Should you be running bolt on spacers.
A slight interference on the spacer lug nut head to the back of your 19" wheel could cause shaking. Some wheel backs have no clearance pockets like your 17" wheel may have.
Old Jun 25, 2011 | 04:05 AM
jin22gt's Avatar
I got aftermarket spline lug nuts for my rims.
Im not sure what bolt on spacers are??? can u explain?
If 19" gets harsher ride than the 17", its just a harsher ride, as in with more road feedback. But I shouldnt be getting vibrations?? right???
Here are some pics of my rims....
Old Jun 25, 2011 | 04:58 PM
toro12's Avatar
20 Year Member
Your wheels are bolted directly on to the OEM hub and lug studs. You do not have wheel spacers. Take it question to the wheel installer is your next move. Have them examine and test drive it and tell you what the vibration could be coming from.
Old Jun 25, 2011 | 05:33 PM
1904 G Spot's Avatar
I thought we have rear axles only?
CV Boot on the front passenger side?
Old Jun 25, 2011 | 05:46 PM
4D05G35's Avatar
AWD sedan. The sedan comes in RWD and AWD.
Old Jun 25, 2011 | 07:38 PM
Chico's Avatar
if you didn't experience any sort of vibration BEFORE you installed your new wheels...then it's very likely you don't have hub rings on the wheels.
Old Jul 8, 2011 | 08:44 AM
jin22gt's Avatar
Problem solved!
It was my front passenger side axle, that was causing the vibrations. Now I don't got any vibrations and I'm loving my new 19"!!!
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
Row2k
Drivetrain
Dec 27, 2015 04:08 PM
