rim and spring set up need help?
Old Jun 29, 2011 | 11:45 PM
g35 06 blue's Avatar
new to the site was hoping someone could help me out. i have a g35 coupe just bought 19x9.5 in the rear and 19x8 in front with 275/35/19 rear and 245/35/19 in the front . was going to lower it but new to the game and not sure what looks good dont want to roll fenders i guess looking for a good spring sizes and a good spacer size if needed thx
Old Jun 29, 2011 | 11:56 PM
hologram's Avatar
With that setup you probably would rub if you didnt roll fenders unless your offsets are really high.
Old Jun 30, 2011 | 12:23 AM
4D05G35's Avatar
What are the wheel offsets so we can assist you?
Old Jun 30, 2011 | 06:55 AM
rims
What is the offset? Can I have a example.
Old Jun 30, 2011 | 08:21 AM
4DGS's Avatar
It will be a number printed on the back of the wheel usually looks like "et +xx"
If you bought these new they are should have been selectable when you bought the wheels. Look for a number with a + sign in front of it.
Old Jun 30, 2011 | 08:48 PM
sorry it took so long dont have the rims now be here tomrw had to call and the offset. its a 20mm let me no what you think
Old Jun 30, 2011 | 09:29 PM
4D05G35's Avatar
You could probably get away with a 15mm spacer in the rear and 20mm spacer up front. The best way to determin that for sure is to get the wheels on the car, lower it to where you like it and have an alignment done. Once thats all done you can then measure from the tire sidewall out to the fender to figure out how much room you have available to move the tire out. I would roll the rear fender a little so you can get the wheels a little more flush, it will look better IMO.
As far as drop, it depends on what you are looking for. Slight fender gap, no fender gap, tires tucked, etc.
The shocks and struts are probably getting close to needing to be replaced so I would just do it all at once and get some coilovers. You get new shocks and adjustability to suite your liking and driving style. You will spend slightly more, but it's well worth it..trust me and everyone else that will recommend them to you.
Old Jun 30, 2011 | 09:33 PM
got a special brand that you would recommend? looking to close the gap between tire and fender
Old Jul 1, 2011 | 12:00 AM
4D05G35's Avatar
Well I have a sedan so naturally I started with OE 350Z springs for a 1" drop, I then tried a few combo's (350z and G35 coupe springs etc). The ride with those springs was decent, given that they were all OE springs. I also had new 350Z Tokico HP shocks/struts with the above springs. I wanted to go a little lower so I went with Tanabe NF210's (coupe version) and I really liked the ride comfort, but I didn't like the height. It was supposed to be 1.6F and 1.1R I believe, but turned out to be more like 1.5 front and rear. I sold those and the Tokico shocks and went with these
https://g35driver.com/forums/brakes-...coilovers.html
I am very happy with these. I have had a few little bugs to work out but all in all it's well worth it.
Those are the only springs/shocks that I can comment on with personal experience. I like the ride quality of the Tanabe the best, and the adjustability of the coilovers. I picked them up when they were only $450 shipped. I believe they are now $535 or so now..still well worth it.
The Tein S-tech and H-tech seem to be popular springs, and BC, Stance and F&F seem to be popular coilovers.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
paolojericho11
Sep 11, 2015 07:08 AM
BlackGee35
Jul 31, 2015 11:04 AM
