heads up on suqeeling sound
Old Dec 6, 2004 | 10:32 AM
Will_blueprint's Avatar
I am taking my car in for service tonight. I am experincing a squeeling noise coming from the right rear of my car. It is a constant noise while I am drving, Some times it gets a bit louder when I brake. I thought maybe it was a cracked pad or something but I noice no unsusal marks on the rotor. I have the coupe 18's on there too. I dont think the dealship will have a problem with this will they? I just wanted to know if anyone had the same problem so I can get a heads up on what it may be. Thanks.
Old Dec 6, 2004 | 11:23 AM
nnkfws333's Avatar
Do you have the stock brembro's? If so it's probably just brake dust buildup. I had a squeeling from my front drivers side tire and only when my wheel was turning to the left...well sprayed some brake cleaner on the rotors and it went away.
Old Dec 8, 2004 | 03:44 PM
The dealership says its a cracked rear brake pad, I guess I will see when I pick it up today.
g.spot
May 9, 2016 10:54 PM
1Typhoon
Sep 25, 2015 08:45 PM
JustinMKN1
Sep 18, 2015 03:40 PM
Albanian122
Sep 12, 2015 04:02 PM
