OK, Let's Do a "Best Wheel" for 2004
Old Mar 24, 2005 | 01:51 AM
  #151
crai6m4ck's Avatar
Someone should take a tally of all the different rims mentioned and a vote count for each or start up a poll with the top mentioned rims!
Old Mar 24, 2005 | 11:44 AM
  #152
nismoGcoupe's Avatar
Originally Posted by joenismo
You will need to take a air saw and trim the inside lips of the quarter panels. Just the flat part that goes in towards the tire(you can feel it with your fingers). If you don't do this 90% of the time it will be OK, but if you corner hard, or hit a bump in the corner, it will rub. If you do not have an air saw, I would recommend swinging by a local bodyshop and having them do it for you. Should cost about $5 or free. Because if you try and roll that lip yourself it will often crack the paint on the edge and can lead to rust and paint work in the future.
Couldn't cutting the lip lead to rust also? since the edge of the part you cut off will be exposed to water since its not being protected by a clearcoat like it is from the factory.
Old Mar 24, 2005 | 09:23 PM
  #153
joenismo's Avatar
Yes it could, but you can just use some touch-up paint along the edge where you have cut. At least you will have a nice edge on the inside, if you roll it you run the risk of it pealing on the outside of the quarter where you can see it.
Old Mar 25, 2005 | 10:11 AM
  #154
Do you know if iforged makes all there wheels the same offset for coupes with brembos? cause maybe I have a set that isn't as agressive as yours cause by the look of it I think I have some room to upgrade to the 285 with out rubbing and that with the spacers I pretty sure I can clear the fender when I take the spacers out.
Old Mar 25, 2005 | 02:27 PM
  #155
joenismo's Avatar
I am not sure about the offsets, but I think they are all the same. I had 285/30/20 and did not use the spacers, and just barely rubbed before I trim my inside quarters.
Old Mar 25, 2005 | 03:35 PM
  #156
dinkman94's Avatar
Here's mine
20" gunmetal volk gtc's with tein springs, the day they were installed...
Attached Thumbnails OK, Let's Do a "Best Wheel" for 2004-pict0077b.jpg   OK, Let's Do a "Best Wheel" for 2004-pict0079.jpg   OK, Let's Do a "Best Wheel" for 2004-pict0099.jpg
Old Mar 25, 2005 | 03:39 PM
  #157
Wicked_limitz's Avatar
^^^ SIck!
Old Mar 26, 2005 | 02:16 PM
  #158
Asianicboi's Avatar
It's all about the RH Pro J5 Super Black Coating Finish =]
NOW THIS IS NO CONTEST =]
Old Nov 6, 2005 | 06:02 PM
  #159
mrjonang's Avatar
Anyone have a pic of turbomaximas wheels, everyones saying there HOT but the damn pix on here are all messed up
KruZZe
Feb 27, 2023 05:04 PM
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
NailBomb
Oct 28, 2015 07:53 AM
alinero718
Sep 27, 2015 09:35 PM
