Rear Sway Bars?????
Old Dec 8, 2004 | 10:31 PM
g35sammy's Avatar
Rear Sway Bars?????
hey guys i've read through most of the threads and lots say just to get the REAR sway bar? is that possible. i thought they come in pairs? if someone can point me in the direction to just get the rear and is also ajustable i'd appreciate it!!!!! thank you so much!
Old Dec 9, 2004 | 01:42 AM
kenchan's Avatar
Just get the stillen set and use the rear. Its only like $275.
You'll always have the fronts just in case you want to go a little
tighter down the road with wider/stickier tires.
Old Dec 9, 2004 | 08:08 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
350 Evo has a rear only available
HERE
Old Dec 12, 2004 | 02:59 AM
subrobo's Avatar
Stock sedan got sway bar already right?
Old Dec 12, 2004 | 03:41 AM
g35sammy's Avatar
not too sure....i know the coupes come with them.....maybe if you got the sports package??
Old Dec 12, 2004 | 06:57 AM
lucidazn's Avatar
Get the front ones also. It helps. I first did the install of the fronts alone and drove around. Big difference.
Old Dec 12, 2004 | 09:46 AM
kenchan's Avatar
I ended up putting on the fronts yesterday (stillen). rear alone was good but the
Pilots can handle front soft/rear medium setting without problems, so you should
get both installed. (not yet tested in wet).
Old Dec 12, 2004 | 10:22 AM
SteveAreno's Avatar
Most all cars have anti sway bars.
Old Dec 12, 2004 | 05:59 PM
subrobo's Avatar
i purchased nismo sway bars (front/back)...and it look just like the stock one, only difference is the nismo one is kindda bigger then the stock one...
Old Dec 12, 2004 | 07:57 PM
jim@streetimage's Avatar
Hotchkis Sways bars are the way to go .
rezendvous420
May 31, 2020 01:26 PM
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
TreeFiddy
Aug 10, 2015 06:50 PM
wuppiedog
Aug 7, 2015 11:16 AM
