Nitto NeoGen V. Falken 452
Old Aug 22, 2011 | 05:35 PM
Calvin's Avatar
Overglorified Altima
I have NeoGens. Love them.
Old Aug 22, 2011 | 06:39 PM
thn116's Avatar
Did you have any of the problems that were mentioned above?
Hows the tread wear? Even with camber?
Old Aug 22, 2011 | 06:42 PM
thn116's Avatar
Nitto 555 blow!!!! Neo gens are great!! I had them on my old rims and running negative camber and they wore evenly..
How much camber were you running? Did they wear quick? My buddy had a set and said he had to get new ones at 8K.
Old Aug 22, 2011 | 06:58 PM
B L U E S L A T E's Avatar
Honda Accord
NeoGen's are great for camber'd setup.
Old Aug 22, 2011 | 07:20 PM
bluedevils95's Avatar
All i can say is, stay AWAY from Falken! I only hear bad stories about them. Stick w/ the Nitto.
Old Aug 23, 2011 | 12:25 AM
2K6G35c's Avatar
Second set of Falken 452's and all I can say, never been happier with any tires. Nitto 555's were the worst tires I ever had, on any car. Bridgestone Potenza were starting to wear at 11K.
Disclaimer, even though I have a 6spd. with all breathing mods available and sport premium package, limited spirited driving. Right now my rears have 30K and they're half way done, my fronts have 17K and look new. Again, that's on stock wheels, no camber wear whatsoever.
Old Aug 25, 2011 | 08:49 AM
thn116's Avatar
So decided to get the NegoGens. I have a noob question though. I was on the Nitto website looking at the 225/40/18 NeoGen and the width spec states 7.5-(8.0)-9.0. So is the 8.0 the ideal width for the tire and the 7.5 and 9.0 are the min and max widths the tire can fit on? I'll be putting the 225 on a 8.5 rim.
Old Aug 25, 2011 | 10:57 PM
4D05G35's Avatar
Yes the 7.5" - 9" width is what they recommend. The 8.5" wide wheel that you are running falls within that range so i'm not sure what you are trying to ask. The "ideal" wheel width is what they specified. Obviously you can venture outside that range(stretched tires as an example), but thats what they recommend.
Nightm4re
Jan 5, 2010 02:46 PM
Sharkroy
Nov 3, 2009 05:57 PM
Ching1206
Feb 22, 2009 03:27 PM
