nismo lmgt4 vs. stock rear tire
Old Dec 13, 2004 | 04:09 AM
dkimx15's Avatar
would the lmgt4's look bad with 245-45-18( stock rear) and 275-40-18 ( aftermarket) ? just wondering my rear tires can be used for the new wheels
Old Dec 13, 2004 | 07:59 AM
lowrider's Avatar
The stock rears would be to high to use in front. 240/40/18 is the correct size, and that tire has a outer diameter that is 1" less than the 245/45/18. the 245/45/18 would end up being the same height as the rear tire, and throw off the stagger and the VDC. It would be better to use the stock 225/45/18 tire, although that would induce more understeer. Also, when you have a performance car, you use performance tires. Performance tires and more unique to each other than normal passanger car tires. The performance specifications built in to one brand of tire might interfere with another. In other words, it's best to put on brand of performance tire on your new wheels in the correct sizes.
Lou
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
yoyoyo8
Aug 12, 2015 03:04 AM
nascarbuff17
Jul 16, 2015 10:23 AM
