Who Has VarrsToen Wheels on their Cars?
Old Feb 24, 2012 | 06:38 AM
  #631
Drew113's Avatar
Ban Hammer Expert
And that is why I said be careful...
Old Feb 24, 2012 | 09:46 AM
  #632
Matzo Ball's Avatar
thin metal = easy bends. That is why reps are always a crap shoot.
Old Feb 24, 2012 | 11:56 AM
  #633
Drew113's Avatar
Ban Hammer Expert
Most are yes....some are actually reliable however
Old Feb 24, 2012 | 05:12 PM
  #634
VarrsToen's Avatar
Originally Posted by aa2033
^ Varrstoen, could you address the bending on the lips? Is this normal with the thin metals?
Bending of the lips can be caused from the material being too thin along with cracking or breaking.
We now use a new factory that uses a stronger grade of aluminum and a bit thicker to avoid any damages. However, the more material there is the more weight.
Potholes and curbs can be an issue as well. Although most wheels are built to withstand them, there are certain amount of impact that will damage the wheels so it varies.
Old Feb 25, 2012 | 11:24 AM
  #635
aa2033's Avatar
bah, i'm so torn if i should get the es 1.1.2 or not.. I don't want these being destroyed easily -_-...
Old Feb 25, 2012 | 11:49 PM
  #636
yusoslo's Avatar
The cracked wheel was verified as another manufacture from a ton of posts I read. Also they resigned their wheels and the cost has gone up. Lastly I bent a Volk TE37 TA on a pot hole, there are a lot more reps on the road then gens and the reps are dailied more. Any wheel can bend. I have 2 bend 18's on a factory 70k car, my BMW 550i sport. Any wheel can be damaged. the other guy mentioned a car hit his rim!
So anyways they are easily replaceable, I wasn't happy trying to replace a discontinued Volk so now I look for affordable nice wheels.
BTW I stripped the clear on 1 and have been testing some polishing. Here is a shot. I only polished 6" on the lip, which is the shiniest part below. I am finishing all of them tomorrow.
Old Feb 26, 2012 | 03:02 AM
  #637
2fly4em's Avatar
Siick cant wait for end results..
Old Feb 26, 2012 | 09:56 PM
  #638
yusoslo's Avatar
Done.
Old Feb 26, 2012 | 10:39 PM
  #639
pbabajan's Avatar
^^^niiice
Old Feb 27, 2012 | 02:30 AM
  #640
johns-g35's Avatar
seems like it needs more shine.. . how are u doing it?
Old Feb 27, 2012 | 02:33 AM
  #641
2fly4em's Avatar
Sweet! Share how you got them mirror polish
Old Feb 27, 2012 | 08:25 AM
  #642
yusoslo's Avatar
Aircraft stripper. Then use wd-40 as your wet sand lubricant. 800-1000-1500-2000 then 0000 steel wool then jewelers rouge on a drill powered polishing pad, then mothers polish, then 3 coats of optibond.
It is a mirror shine, the first set of pics where just a 2000 and polish test spot. The most recent is 3-4 hours per rim, finger bleeding process. The hardes part is sanding out the grooves in the machined lip so it's flat.
Old Feb 27, 2012 | 11:37 AM
  #643
johns-g35's Avatar
Yeah man It does take for ever
But I know a better way
Lift the rear of ur car up
Mount ur new wheels on
Put ur car on 3rd gear.
While spinning start with a 400 grip and work ur self up till 2000 lol .
20 minutes per wheel
Old Feb 27, 2012 | 12:18 PM
  #644
Frankieg35's Avatar
Looks much better..
Old Feb 27, 2012 | 01:43 PM
  #645
VictoriousG's Avatar
Too much work for reps but they do look a lot better..
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
