will 19x10 fit on front?
Old Nov 2, 2011 | 01:44 AM
  #31
R6n350GT's Avatar
Originally Posted by 4DGS
the 285 will be the more suitable option in this case.
so 30 profile is way too small? what does 30 vs 35 make to the car? dam, im not having much luck getting my 295, thats the whole reason for getting the new rims lol
Old Nov 2, 2011 | 01:53 AM
  #32
4DGS's Avatar
30-35 in the same tread width is about an inch in overall diameter.
Old Nov 2, 2011 | 03:31 AM
  #33
R6n350GT's Avatar
I see, so running on 30, an inch less will mean it's just going to wear alot faster (5000miles less for eg), going to be a more harsh noisy ride, not handle aswell in corners, not brake as well ? How does it affect it and why do they only do 30 size dam them!
Oh and on another forum they said if i cant wait for 255/35 to come into stock and i go 255/40 with rear 295/30 then the car will not look right with such a difference in side walls.. arrhhhh god dam tire options.... what if i went 265/30/19 for the front over 255. May do that to keep both wheels at 30 sidewall. But 4DGS if you let me know about how **** 30 is over 35 and 40 and convince me to go 255/40 and 285/35 .... rather not but you know much better than me !
Old Nov 2, 2011 | 01:59 PM
  #34
R6n350GT's Avatar
After hearing the 255/35 will be upto 60 days away and reading http://my350z.com/forum/wheels-and-t...at-fronts.html i have made my mind up and ordered.
265/30/19 and 295/30/19, thx so much for your help 4DGS, ill post pics when they are all on!
Tirerack said i may need 5mm spacers.. so H&R ones ill order.
Old Nov 3, 2011 | 08:14 AM
  #35
idrive_MD's Avatar
I ran 285/30/19 front and 305/30/19 front with 19x10+20 and 19x11+23 without a single problem...I'd go with the 285/30/19 in the front at least and at worst you would probably need a 10mm bolt-on hubcentric spacer, adaptech makes some really nice ones I hear.
Old Nov 3, 2011 | 05:18 PM
  #36
R6n350GT's Avatar
285 in the front, wow. Can you show me pics i already ordered the 265. my rear is not wide enough for 305
Oh and im getting the same wheels as you, what do you think about them, how many km you get out of them?
Old Nov 4, 2011 | 12:11 AM
  #37
idrive_MD's Avatar
search some of my post history and you'll find some good shots...sorry for being lazy.
Old Nov 4, 2011 | 09:34 AM
  #38
R6n350GT's Avatar
i saw the one in the thread i replied in. You wanting to go 295 in the fronts.. god dam!
with my offset without spacer and at 10" whats the biggest i can go in front before it makes handling worse?
Also you think i will get away without spacers? its like $125 to get 5mm and if i buy them and dont need them it will suck!
You need some rear shots !
Old Nov 4, 2011 | 09:44 AM
  #39
Adil_G35's Avatar
If you really are thinking about spacers you should do some measurements bro. Don't waste money if you don't need it
Old Nov 5, 2011 | 11:46 AM
  #40
G35sedan03's Avatar
That's actually not my car lol it's the one you posted from rimtuck.com.
This is my car
The 295/30 is a little on the small side to be honest.
What kind of deal is it on these wheels? I think for what you're going to pay for wheels and tires you could easily pick up a very high quality set of forged wheels with tires in better specs with a stagger!
damn that setup was sick, that was something i was shooting for, either 10.5 or even 11 on the back.
Old Nov 7, 2011 | 07:55 AM
  #41
idrive_MD's Avatar
My wheels without spacers are 19x10+20 in the front. If you are getting a 19x10+30 like you mentioned, than I would just a 10mm bolt-on spacer kit, slap on some tires and be done with it. 265/35/19 or 285/30 are my suggestions.
Old Nov 11, 2011 | 10:41 PM
  #42
R6n350GT's Avatar
Tires all installed
Fit perfect except for 2 things
1. valve stem too long and hitting front calipers so i had to cut them down. Im looking for some 90degree ones so let me know where to get them!
2. Front needed 3mm to just clear the caliper. Im going to get proper 5mm H&R hubcentric bolt on ones.
Tire size
265/30/19
295/30/19
I would have rathered 35 profile but not avaiable in Hankook V12 Evo
Pics
Front
Rear
Notes:
No further guard rolling that stock and not srubbing
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
BlackGee35
Jul 31, 2015 11:04 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
