Worn rear + new front = low trac?
Old Nov 1, 2011 | 09:32 PM
brn2drive's Avatar
I just got back from the dealer to diagnose low trac and VDC off lights that wont turn off. I was told the yaw rate sensor is bad (the sensor that controls the traction control).
My question - I just had the front tires replaced under road hazard waranty so they're brand new. Now my rear tires are at about 4/10ths and nearly shot. Would the computer trip these lights because the rear tires are spinning slightly faster than the front tires because they're worn?
What do you all think?
Old Nov 2, 2011 | 12:11 AM
4DGS's Avatar
Are the tires the same size in over diameter? (what size are the tires)
Old Nov 5, 2011 | 10:20 AM
brn2drive's Avatar
All stock 19 inch size.
Old Nov 5, 2011 | 09:56 PM
keithk831's Avatar
I had my "Slip" light come on occasionally on turns and hard downshifts when my tires were almost dead. Replaced all four and the problem never came back.
Not exactly the same problem, but maybe this will help. Just replace the rears and see what happens.
Old Nov 13, 2011 | 01:14 PM
brn2drive's Avatar
Thanks. I feel like its probably a sensor problem after reading through a few others that have had this problem.
Is there a good source online to buy used/salvage parts?
Old Nov 13, 2011 | 01:37 PM
bluedevils95's Avatar
You can check the junk yard for some cheap parts if you know what to look for.
rezendvous420
May 31, 2020 01:26 PM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
st33zygill
Jul 29, 2015 10:05 PM
wojowojo16
Jul 27, 2015 09:57 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
