What Spacers fit OEM Rays 19's???
Old Nov 17, 2011 | 05:27 PM
Jhambor's Avatar
Well, I **thought** I was going to install my newly purchased wheel spacers today, and go to find out the hubcentric ring built into it doesn't fit into my OEM 19" Rays. Anyone put spacers on your OEM 19s? If so, what kind, where from? Thanks.
Old Nov 17, 2011 | 05:34 PM
Xet's Avatar
Xet
How is it not fitting? What size spacers? You either bought the wrong bolt pattern, bought smaller spacers with built in lugs that causes your stock lugs to block the rims from fitting, or if you are talking about the fronts didn't remove the little metal piece blocking it from being installed.
But just in case, I ran project kics and ichiba v2's 25mm spacers on my oem rays, if you want to buy them just pm me.
Old Nov 17, 2011 | 05:35 PM
takaG35's Avatar
Did you get the ichiba V2? I got mine from B2...vendor on here, I think they are in FL too.
Old Nov 17, 2011 | 06:09 PM
Jhambor's Avatar
It appears to be the hubcentric ring that is built onto the spacer....it doesn't fully fit into the back of the OEM wheel. The hole appears to be tapered on the wheel itself...and on the spacer, the ring is not tapered. Atleast, that's what it looks like.
Old Nov 17, 2011 | 06:31 PM
Adil_G35's Avatar
Please describe what spacers there are the be sure your bolt pattern and everything is right? Where did you buy it from?
Old Nov 17, 2011 | 07:00 PM
Jhambor's Avatar
They're off of ebay. Bolt pattern is fine....it's just the hubcentric ring doesn't fit into the rim. Listing specifically said it'd fit my car, guess not, unless they sent me the wrong one. Hopefully they refund me!
Old Nov 17, 2011 | 07:04 PM
Canadian's Avatar
Canada, eh?
eBay. That's your problem.
Old Nov 17, 2011 | 07:13 PM
Beebo's Avatar
+1 id never run cheap eBay spacers on my car
id rather not have my wheel come off while doing 80 on the highway
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
laksjd84
Steering & Suspension
14
Aug 8, 2015 11:47 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
mushu
Jul 15, 2015 03:55 PM
