suspension interchange b/w G35c and 350Z
Old Jan 2, 2005 | 03:27 PM
sbenso's Avatar
does anyone know if all or any front suspension parts interchange b/w a G35c and a 350z? ie: control arms, coil, strut, etc.
thanks
Old Jan 2, 2005 | 04:32 PM
aLL STaR gene's Avatar
I was told by several people that the setups are the same, the only difference is the spring rates for the rear. The G is heavier so it was recommended to swap the rear springs out to either application needed.
Old Jan 2, 2005 | 07:19 PM
sbenso's Avatar
I just need to replace the passenger front, but everything, it was wrecked and I cannot find the "knee assembly"(everything control arms lower and upper, spring, strut, etc.) at any salvage in the US. then I saw that someone said something about g35/350z parts interchanging and thought I could possibly find these parts easier.
Are the springs the same for the front?
thanks
Old Jan 2, 2005 | 09:06 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Actually the OEM spring rates for the Z, the G35c and the sedan with the sport suspension are all the same rate.
314 front & 342 rear.
The only dif is the ride height & shocks. (aprox 1/2" dif between each).
Mounts & control arms are the same part #
Old Jan 3, 2005 | 12:03 AM
sbenso's Avatar
so if I got everything except for the spring and strut off of a 350z or g35 sedan and found a strut and spring for a g35c, it should all go together and be the right ride height?
Old Jan 3, 2005 | 08:03 AM
InTgr8r's Avatar
Yes, spring & shock are the only thing different
Old Jan 3, 2005 | 09:20 AM
sbenso's Avatar
thanks for the info.
Old Jan 23, 2005 | 03:51 PM
user 4560487's Avatar
when you sat 1/2" diff between each, do you mean, sedan>coupe>350z
meaning if i put 0.6" drop 350z springs on a coupe or sedan, it'll lower the coupe 1.1" and the sedan 1.6"????
Thanks!
Old Jan 23, 2005 | 04:07 PM
kenchan's Avatar
Thanks!
yah, from the reading, that looks like the case. The 350Z struts are shorter than the coupe and sedan so it will lower it more. (im very glad I did not get the Prokit for the 350z... would've been too low).
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
DRG35R
Jan 31, 2016 07:14 AM
Patrick Bovee
Oct 1, 2015 10:42 AM
doakley92
Sep 25, 2015 12:58 PM
