19x11 +15 Front tire selection
Old Feb 7, 2012 | 10:31 PM
yusoslo's Avatar
I want to run a 255/35/19 all around, car has -1.7 camber up front. Tires will be V12. I am running 255.35/19 in the rear on 19x11 +0. Will it rub, I dont feel comfortable putting a 235 on a 11.
Old Feb 7, 2012 | 10:34 PM
G35xTurbo's Avatar
Pics, suspension setup? That would help someone help you?
Old Feb 7, 2012 | 10:37 PM
yusoslo's Avatar
my drop eibach sportline 350z
Old Feb 7, 2012 | 10:41 PM
parhamm1's Avatar
255 should be fine. Are your fenders rolled? I'm going to be running a 275/30 on a 20"x11" +3 and I'm lower than you. I have my fenders rolled flat and ever so slightly pulled.
Old Feb 7, 2012 | 10:42 PM
parhamm1's Avatar
What wheels are you going to be running? Front specs?
Old Feb 7, 2012 | 10:43 PM
parhamm1's Avatar
Scratch everything I said. I didn't realize you were talking about fronts...
Old Feb 8, 2012 | 01:24 PM
yusoslo's Avatar
Yeah fronts. Anyone else know
Old Feb 8, 2012 | 11:31 PM
yusoslo's Avatar
Trying to buy tires tomorrow , any help?
Old Feb 9, 2012 | 01:32 AM
GARRYDG07's Avatar
I have a 19x11 +5 w/ 15mm spacer and I'm running a 245/35 and I just removed fender liner,screws and a roll but sometimes wish I would've gone 235/35
Old Feb 9, 2012 | 08:18 AM
yusoslo's Avatar
Thanks Gary! So you are pretty much at -10 offset right?
Old Feb 9, 2012 | 12:45 PM
GARRYDG07's Avatar
I'm at 11 +5 after the spacer
Old Feb 10, 2012 | 11:03 PM
yusoslo's Avatar
thanks. I think I am going to go with 245 in the front to be safe, I can then on my next set go 255 if there is enough room in the fender
Old Feb 14, 2012 | 12:17 AM
dub_clutch's Avatar
I jus got sum 18x9 n I was wondering wat size tire would fit good wit these I was thinkin 255/45 but I'm not sure ....... Input pls
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
derres
Aug 28, 2015 03:27 PM
Fireman07603
Aug 9, 2015 06:00 PM
Popes
Jul 29, 2015 05:07 PM
rping
Jul 26, 2015 09:53 PM
