285/30/20 ???? Can I ???
Old Feb 8, 2012 | 04:27 PM
madmaxx72's Avatar
Hey guys i just got a set of Sevas S22 they are 20x8.5 and 20x10 and 25mm offset all of them that will be mounted on a G35 Coupe , The car will not be dropped it will maintain stock height it is equipped with the sports package, can i install 285/30 in the rear and 245/35 in the front??? or will i have to roll the fenders in the rear to clear these??? Thanks. both tires are 26.7 high...
Old Feb 8, 2012 | 06:42 PM
GarageLife's Avatar
It'll fit for sure, but you might have roll the rear on the soft, stock suspension.
Old Feb 8, 2012 | 07:17 PM
broke_as_ajoke's Avatar
I run that same setup.. with tires, but my rear will is 20/30/11. You wont have to roll them at stock height unless ya springs and shocks are bad.. I rolled mine, cuz I knew I was gonna lower my car
Old Feb 24, 2012 | 11:10 PM
joeb1983's Avatar
G35
It should not be a problem at all. I'm running 20x10.5 +30 in the rear with 285/30/20. Plenty of room and I'm lowered.
Attached Thumbnails 285/30/20 ???? Can I ???-106.jpg
Old Feb 25, 2012 | 05:06 PM
BmoreIPdriver's Avatar
you should have plenty of room .... Im running +25 on s.tech with the same tires with NO problem
MahdiG35
Mar 28, 2006 07:24 PM
OvaYahead
Mar 17, 2005 12:38 PM
Bashar368
Apr 21, 2004 09:54 PM
