pulling off an agressive setup
Old Feb 22, 2012 | 04:43 PM
alex526's Avatar
I am going to be buying concept one RS8 wheels 20x8.5+18 F 20x10+20 R
(i know they arent on the level of works or volks or anything but i think theyre a nice rim)
ANYWAY
im thinking 225/30/20 F and 245/30/20 R
im going to use 15mm spacers up front and 20mm out back
How does this setup sound?
I will also be dropped on tein basics
Thanks
Old Feb 23, 2012 | 06:37 PM
4DGS's Avatar
1. Not wide enough to work
2. tire sizes are.... meh
3. Why not buy correct fitting wheels instead of buying wheels and then dropping another $300 in spacers?
4. Don't buy tein basics if you want to go aggressive, you will regret it and sell them.
5. Coupe or sedan?
6. Please ask this in the wheel and tire section
Old Feb 23, 2012 | 06:58 PM
alex526's Avatar
5. Coupe or sedan?
Well do you think I'd be able to be at least flush with this setup ? And only reason for not getting the correct fitting wheel is because these are what I want and those are the lowest offsets they come in, so I figured wheel spacers would fix that issue. This is for a coupe.
Old Feb 23, 2012 | 07:30 PM
4DGS's Avatar
You're better off getting 20x10 all the way around, running 235 or 245/35 and running 25-30mm spacers.
Old Feb 23, 2012 | 07:40 PM
alex526's Avatar
true never thought of that, ill look into it. and also just curious but why do you think i wouldnt be happy with the basics?
Old Feb 23, 2012 | 07:42 PM
4DGS's Avatar
They don't go very low, they have no dampening and they just aren't stiff enough for aggressive set ups.
You would be much better with a set of BC racing coils for like $800 shipped brand new.
Old Feb 23, 2012 | 07:51 PM
alex526's Avatar
Thats even cheaper then the basics, where can i get them shipped for $800?
Old Feb 23, 2012 | 11:57 PM
4DGS's Avatar
Check out the vendors on this site, they're anywhere from $600-$800 used as well.
Old Feb 25, 2012 | 05:30 PM
4DGS's Avatar
Good to hear!
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
DRG35R
Jan 31, 2016 07:14 AM
AL8782
Oct 3, 2015 10:26 AM
