Help! tire wearing problem
hello i was looking for some advice or what can be the problem. I have VarrsToen Wheels 9.5 ; 10.5 +12 offset. 245/30/19 front and 265/30/19 rear. The front are fine and have even wear as should however the rear, the sides of tires are still meaty but the center most part is worn out(more worn out), i checked pressure. what should be the pressure or problem in this?
thank you, please let me know
my car is lowered and i have spc rear and front camber arms
Sounds like a tire pressure issue to me. Just curious though, when is the last time you've stopped by the alignment shop?
how long ago did u get and have your alignment done? Have u made any adjustments since then? ie.. Camber, lowered more (coilovers if that's what you have)?
Possible toe issue if pressure is good. If toe is off you're basically dragging the tires behind the car while driving. Mine was off two years ago and I burned through a pair of rear tires in less than 6 mo. Wear started in the middle and was perfectly even across the the tire by the time I realized it.
Hello Guys,
I have a 2004 coupe 6MT. I have 245/35/20 tires in fronts on 20X8.5 rim and 275/30/20 rears on 20X9.5. I don't drive my car during the winter and I'm not an aggressive driver. All four of my tires are wearing out in the inner edge of the tires. The outside and center of the tires looks good but the inner edge are wearing out fast
. I had the dealer check the alignment but keep having the same issue. I'm getting ready to by another set of tires but before I do so, I wanted to find if anyone else has experienced this problem and how did they fix it.
I've told the tires on tilted in on these vehicles and that is why they are wearing out in the inside. I was suggested to install an after market camber kit, in order solve this issue.
Please help
Thank you
. I had the dealer check the alignment but keep having the same issue. I'm getting ready to by another set of tires but before I do so, I wanted to find if anyone else has experienced this problem and how did they fix it.I've told the tires on tilted in on these vehicles and that is why they are wearing out in the inside. I was suggested to install an after market camber kit, in order solve this issue.
Please help
Thank you
FS[Canada]: 19" Rays Volk LE37 Wheels Rims with Falken Tires
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
Fireman07603
Aug 9, 2015 06:00 PM
